2016 F-Type R Misfire Diagnosis
Hey all, I'm having some issues with misfires in my 2016 F-Type R AWD (~56,500 miles) and am not feeling the most confident in what the shop is telling me, so I figured I would get your guys' opinions.
The last time I drove my F-Type (November 2025) I began having misfire issues immediately after a hard pull. I immediately parked it in my storage unit afterwards (it happened as we were pulling in to the lot). When I pulled the codes, I got:
- P0300 - Random misfire detected
- P0301 - Cylinder 1 misfire detected
- P0302 - Cylinder 2 misfire detected
- P0303 - Cylinder 3 misfire detected
- P1315 - Persistent misfire - catalyst damage
- Also, a historic code from 2024: P0088-85 - Fuel rail/system pressure too high (the CEL came on, but cleared on the next start-up and hasn't returned since then)
- Replacing both high pressure fuel pumps
- If replacing the high pressure fuel pumps doesn't solve it, then replacing all 8 fuel injectors
- Confirmation of which cylinders and bank(s) are misfiring and whether everything points to Bank 1 only
- If they have already ruled out ignition issues on cylinders 1-3 (specifically spark plugs and ignition coils - if they have inspected the plugs and whether or not they have tried swapping coils to see if the misfire follows)
- Under what conditions do the high pressure fuel pumps show inconsistent readings (idle, under load, etc)
- If there are inconsistent readings, are they isolated to Bank 1's high pressure fuel pump, or are both pumps showing problems
- Year: 2016
- Mileage: ~56,500 miles
- VelocityAP ECU tune (stock upper and lower supercharger pulleys, not upgraded)
- VelocityAP 200 Cell Sport cats and downpipes
- Car is usually driven only 1x a week to car shows and cruises afterwards for ~6 months of the year (average, maybe 3,000 miles a year)
- I don't push the car to the max. May drive it mildly hard every once in a while, but nothing crazy at all
First thought is to eliminate low battery voltage causing random electrical glitches - fully charge the battery and start diagnosing from there. Apologies if you've already done this, but we've all been there .....
I would suspect timing more than a fuel pump itself with that symptom list, but further diag is needed before you throw any parts at it.
Most competent scan tools have a HPFP test function that will disable them one at a time while running and compare, to diagnose if one is failed. Good place to start.
There is ONE issue that is causing all these errors - throwing parts at it is irresponsible and very expensive. Replace both fuel pumps? Replace 8 injectors? What are the odds multiple parts have failed at the same time?
I agree with you and @RoverJoe - start with Bank 1, swap coils, check fuel pump function. Also checked for any frayed or loose wires / plugs.
Please keep us posted on your progress and good luck!
PS You are not alone currently:
https://www.jaguarforums.com/forum/f...1/#post2914649
Yep, you're on the right track. I call this the "Shotgun" diagnosis method. They do this all the time but would never do this with their money.
There is no chance that several parts failed together, in a single event. Much more likely a single component failed which impacts the fuel rail system.
Sparkplugs and Coils problems will be reported on the ECU. The algorithm that measures and reports ignition parts, works very, very well. Sparkplugs that fail in this engine, are never caused by the sparkplugs themselves. If an ignition coil fails, it's a solo act. A coil failure could cascade to trash that plug, even a cracked plug insulator could cause that coil to fail.
You have reports on every plug in one back, and 0 reports on the other bank. This indicates neither the plugs nor coils caused this problem. If you roll components between banks, you will move a set of parts just challenged to operate in a struggling mode.
Each Bank has some exclusive sensors. Whenever symptoms affect the full Bank, and 0 affect reported on the other bank, shift focus to every sensor exclusive to the affected Bank. If NTF, I'd then prove every actuator operates when I manipulate the relative sensors. I start with external actuators.
Here's a smoking gun... 1315 - Persistent misfire - catalyst damage. This one seems like it is a suck factor of 10, but it is a powerful clue. The message is a wee bit misleading.
This alert was developed due to top-down pressure on Engineers to identify conditions which they expect will harm the CAT. The misfire was measured, logged, and accumulation of misfire reports triggered this alarm. It does not measure catalyst damage, only things which they've recorded that cause damage. It precisely measures Crankshaft rotation and records events when the crankshaft angle position arrived too late or too early. The rate of errors is continuously tracked. Your engine exceeded this performance window.
We know this engine is definitely misfiring, isolated to Bank 1. We know misfires only occur immediately following high torque demand mode, or high fuel volume demand. Many actuators operate to enter and to exit this mode. Most never operate otherwise.
Now let's dismiss the impossible and improbable.
Impossible
HPFPs, these are mechanical pumps. If one of these mechanically fail, the engine cannot start. The fuel rails are continuously filled with liquid fuel; there is no storage of latent pressure. If the HPFP broke apart, injectors open but no fuel can flow. The fuel pressure is far too high to measure. You can get measured fuel pressure via the OBD comm port. This proves HPFP can supply the pressure, the sensor is reporting to the ECU, and the ECU received it.
Let's clear the dumb, easy, quick stuff. My apologies. Each bank's air supply is unique. Plz check air filter, MAFT sensor, integrity of every air supply connection, and air filter housing. In High Torque Mode, if the engine sucks in any air from the engine bay, instead of the ram air from the front of the car, the ECU adjusts everything to expect more air pressure. It has little to do with air temp, mostly the expected ram air pressure, it responds to high torque demand + vehicle speed with acceleration, so it closes blower bypass, adds injector duty cycle and advance, adjusts cams advance, changes ignition operation mode, & prolly others I forgot.
The ECU then predicts imminent Combustion conditions to control everything I listed for combustion perfection. Your engine's ECU has lost combustion supervision either while going into or out of High torque mode. It is either not able to measure something, or not able to move something within the time limit
The unpopular Tech X reported HPFPs are giving "inconsistent" readings. Hmmm, I don't think HPFPs have a way to report anything. The ECU monitors the Fuel Rail Pressure Sensors to compute fuel injector operation, and to emergency shutdown if fuel pressure is too low or 0.
Impossible
Not exactly, the HPFPs are cam driven, but rely on a solenoid to close to allow them to actually build pressure, and this pulse is timed with the fuel pump cam. If the solenoid fails on the HPFP it can be dead, or just underdriven, say it's commanded to be closed 20mS to generate the desired pressure but it only actually closes for 12, you will get low pressure and all the resulting faults. If they short completely you can cook the driver in the PCM. This circuit has some diagnostic capacity for being open but I've seen plenty of pumps fail and not report codes. The HPFP test to run the engine off one at a time is a great help to diag this properly with less guesswork. If the pump is out of timing it would affect both, as it's a common cam, so that's not really an option here.
Air supply to both banks is shared in the plenum, so intake side is not usually the issue. Cam timing is bank specific and can cause misfires down one side, as can O2 sensor faults and exhaust issues as they do not mix. There can also be a bad ground on one bank, as each side of the engine has a separate ground for it's injectors and coils. I've seen them left loose and it presents like an engine out of time, and if run long enough the backfeed of power through the PCM to ground on the other side WILL damage the PCM. Something worth checking if the valve covers have been off recently or any other work was done on the rear of the cylinder heads. Those little 8mm bolts with the ground wires get missed easy even by experienced techs.
OP. I think I know what is happening here. Fuel injectors 1, 2 & 3, are not opening reliably. Especially when the fuel flow rate is high, these 3 injectors fail to open, or are not open long enough to pass all the fuel that was supplied from the HPFP. HPFPs are mechanical, liquid gasoline is non-compressible. If these pumps push fuel into the Fuel Lines but no fuel injectors are open, the HPFP will push the fuel through its over-pressure bypass valve. The effects are a momentary high fuel pressure, then a sharp fuel pressure drop when the bypass valve opens. Cylinder 1's HPFP is not the HPFP for Cylinders 2 & 3. Cylinder 4-8 are not misfiring. Since cylinder 4 is not misfiring, issues which impact the full Bank 1, are unlikely.
RoverJoe mentioned wiring, grounding, connectors and such. It's likely Injector wiring which affects 1,2, &3 injectors but not #4 should be where you'll find the cause. The injector harness routes from the firewall to engine front, first stop injector 4, then 3,2,1.
The OPs original ask was regarding the intended diagnostic proposal. IMHO, neither of the HPFPs have failed. So that would be a total waste of money. Replacement of all 8 Injectors could get the problem fixed, even if all 8 injectors are good. The Tech would likely clean and fix poor connections during the process.
It's still possible 3x injectors all failed or clogged up while the other 5x are still working. This I could believe, but to have all 3 bad injectors be the first 3, seems unlikely
Taibbath
Oct 25, 2025 10:58 AM
