2016 R - tow hook plate mount vs. parking sensors
Old Jul 7, 2024 | 06:21 AM
2016 F-Type R owner's Avatar
Default 2016 R - tow hook plate mount vs. parking sensors
Hi folks!
If this is a duplicate question, I apologize.
Just got this beautiful car from a non-front-plate jurisdiction. The dealership provided a screw to the fascia plate mount, which I don’t want to use.
So we went with a tow hook mount, hoping to work around the front parking sensors. This doesn’t seem possible, as even in the most extreme outboard position, the sensor is activated. At the moment, I’m just turning it “off” each time it’s triggered (seems to be when shifting into reverse), but this is a bit tiresome.
I suspect there’s no elegant solution and that I’ve just made a bad call here.
All suggestions are welcomed.
TIA
Old Jul 7, 2024 | 08:04 AM
PaulBarrrera's Avatar
Am I understanding that you have to display a front license plate, do not want to mount it normally, which looks like **** and you're frustated with the other option at hand? Investigate the Sto-N-Go (or Show and Stow, whatever) which allows a plate mounting that doesn't require drilling into your grill bar or blocking the grill. It's in use everwhere and many posters on this site use it. There are other posts below under Related Topics which will describe it better.
Old Jul 7, 2024 | 08:40 AM
DJS's Avatar
DJS
Here’s the thread that Paul’s referring to…
https://www.jaguarforums.com/forum/f...holder-281535/
Old Jul 7, 2024 | 11:16 AM
Valerie Stabenow's Avatar
Originally Posted by 2016 F-Type R owner
Hi folks!
TIA
Yes, do visit the link shared! I have a 2017 and the SnS could not be any easier to install.. do check underneath for the chin/lip spoiler bolt that is used for the install. and here's a link from SnS
https://stonsho.com/products/front-l...type-svr-sns68
Old Jul 8, 2024 | 07:06 AM
SportsEngineer's Avatar
I had the exact same experience with the parking sensors and the license plate mounted using the tow bolt location on my 2015 R. I returned it and bought a Sto N Sho. Super easy install, no issues.
MisplacedPriorities
Sep 4, 2021 12:57 PM
Burt Gummer
Oct 8, 2018 12:17 AM
burbsgirl
May 8, 2018 08:21 AM
Davidrnz
Jan 15, 2018 03:45 AM
alanroberts50
Mar 15, 2014 05:07 PM
