2017 type S Manual Trans engine vibration when decelerating @ specific RPM ranges
Old Apr 19, 2025 | 12:07 PM
scotter's Avatar
Yes, this is correct, the bad behavior has returned and is more frequent. Thanks for your suggestions, we are also reviewing motor mounts, the harmonic balancer and crankshaft pulley.
Old Apr 19, 2025 | 12:11 PM
scotter's Avatar
Good details, thanks. No loose parts were found at disassembly when latest gen components were installed, so as I just mentioned in the post to @Unhingd , we are expanding scope to look elsewhere. Since there is vibration felt when the engine is spinning down with the clutch disengaged, we are turning our focus to components from the flywheel forward.
Old Apr 19, 2025 | 01:33 PM
JagCode3's Avatar
Keep up the good detective work @scotter - we in the MT group are hoping you get a resolution. The entire driveshaft and linkages are suspects at this point.
Paging @HermanWiegman at @Onca Engineering - need your input here!
Quickstep192
Feb 4, 2024 05:30 AM
mbelanger
Mar 31, 2021 11:46 AM
HermanWiegman
Mar 21, 2021 01:06 PM
John Cronin
May 21, 2017 09:01 AM
Mgbams
May 14, 2017 01:46 PM
