2019 jaguar F-Type P0507 rough idle high idle
Old May 19, 2024 | 05:13 PM
pmaniuos's Avatar
Default 2019 jaguar F-Type P0507 rough idle high idle
For 2019 Jaguar F-Type P300 2.0t. Question for the experts. Check engine light went on. After checking, P0507 code shows on OBD reading. Has rough idle and RPM would fluctuate up and down. At times, high idle in park. Took to mechanic and he saw that there was a vacuum line that was not connected. We could not figure out where the line can be connected. Does not look torn off. Just out of place. Then we were able to figure it out and placed into engine mount. He did a pressure test of the exhaust system and found no leaks. It was fine for a few days of driving and the check engine light is back on when I turned the car on as soon as it gets started. Video is included and pictures of hose are also included. I’d greatly appreciate it if anyone has an insight as to what the problem could possibly be. Thank you all.
File Type: mov
Old May 20, 2024 | 05:26 AM
manuninja's Avatar
Have you original air filter?
Old May 20, 2024 | 09:37 AM
pmaniuos's Avatar
Have I changed the air filter? Yes, about 1,500 miles ago.
Old May 20, 2024 | 09:40 AM
manuninja's Avatar
but original one?or k&n or bmc?
Old May 20, 2024 | 11:23 AM
pmaniuos's Avatar
The brand is called filter mann, shop mentioned it was a perfect fit.
retroren
Sep 23, 2022 09:46 PM
Harry Dredge
Nov 2, 2015 12:31 AM
Rotorbug
Jun 4, 2012 11:07 AM
