295 vs 305, front/rear/both?
Old Nov 6, 2018 | 08:07 PM
FType17's Avatar
Originally Posted by Stohlen
Yes, yes... you did say that. And you could also reduce pressure in the original size tires and then we'd be right back where we started with this discussion; which is why i ignored tire pressures.
Cringe all you want, but this admittedly oversimplification is better than people continuing to think a wider tire makes the contact patch bigger and will help prevent wheelspin. I see this statement everywhere and its just plain wrong. Sidewall height/stiffness, compound material/construction, and tire pressure all have their place in this equation, but if you're choosing a wider tire for the sole purpose of reducing wheelspin, you're doing it wrong... and that's the point i'm trying to make.
Always so polite in response to a detailed and technically sound reply. Certain wider tires will provide better traction and reduced wheelspin.... You are incorrect. What I tried to explain extensively is the facts that only looking for a wider tire is NOT a surefire way to have better traction.
Old Nov 6, 2018 | 09:39 PM
Stohlen's Avatar
You're picking at semantics and being difficult as usual. Obviously a wider tire will provide reduced wheelspin if you're going from a street compound to a drag radial... There are even situations where the same model will have an increased longitudinal contact patch in a wider size due to sidewall stiffness changes due to varying sidewall height, but in a vacuum (which I've been saying the whole time) wider isn't better for wheelspin reduction. We can go into all the details and intricacies of a tire and its effect on grip all you like; but unless you're planning on making every member's unique tire decisions for them, that's not going to help anyone. Heaven forbid I try and simplify things.
Old Nov 6, 2018 | 11:11 PM
FType17's Avatar
Next time, try and provide a technical explanation rather than your dictatum. I simply offered a technical explanation allowing everyone to come up with their own conclusions based on FACTS. Of course you did not read or did not understand what I wrote... in any event, I bow to your extensive expertise...
Old Nov 7, 2018 | 08:13 AM
Stohlen's Avatar
Stop acting like you’re smarter than everyone on this forum. It’s getting old.
sinner
May 8, 2019 09:43 AM
draguarxkrsgt
Apr 27, 2017 03:55 PM
vincent661983
May 19, 2014 11:35 AM
OliverD
Jan 23, 2013 10:13 AM
jaguarevan
Jul 12, 2009 03:10 PM
