50K Service - What else should I do?
Old Jun 30, 2025 | 02:46 PM
BigJMaas's Avatar
Default 50K Service - What else should I do?
Ok... 2016 F-Type R. 50K miles. Gonna take it out of service for a minute to do a bunch of stuff. My goals are the following
- VAP Supercharger tune, pulleys (stage 3 or whatever)
- 50K / 10yr Maint Items
- Cooling upgrades
- Brakes (upgraded rotors, powdercoat the calipers yellow)
Below is everything I currently have.... The question is... what else should I do while I am in there?
  • Wipers
    • Denso C2P1268
    • Denso C2P1270
  • Cabin Air Filter
    • Corteco 80000606
  • Engine Air Filters
    • Mann T2R1881
    • Mann T2R1882
  • Engine Oil Change
    • Mann HU8008Z
    • 0W20 Special Tec LR Engine Oil (5 Liter) - Liqui Moly LM20410
  • Differential Fluid Change
    • Diff Oil: Castrol BOT 720 (Jaguar Locking Differential Oil - Genuine Jaguar C2D3650 )
  • Brakes (With Iron Rotors - With 380mm Front and 376mm Rear Rotors)
    • Disc Brake Caliper Rebuild Kit (CLKFL-34021 | Front Left , CLKFR-34021 | Front Right , CLKRL-33015 | Rear Left , CLKRR-33015 | Rear Right
    • Jaguar F-Type R, V8S, V6S Porterfield R4-S Brake Pads Front AP 1750
    • Jaguar F-Type Porterfield R4-S Brake Pads Rear AP 1753
    • Jaguar F-Type R, SVR & V6S Lightweight 2-Piece Front Rotors (Pair)
    • Jaguar F-Type R, SVR & V6S Lightweight 2-Piece Rear Rotors (Pair)
    • PRISMATIC POWDERS® Lemon Drop (1 LB/PSB-8085)
    • PRISMATIC POWDERS® Clear Vision (1 LB/PPS-2974)
  • Supercharger Stuff:
    • VAP: Upgraded Supercharger Belt Tensioner - 3.0 & 5.0 Supercharged Jaguar Land Rover Range Rover Engines
    • VAP: Jaguar 5.0 AJ133 Supercharged ECU Tuning, FType, FPace SVR, XJ, XF
    • VAP: Supercharger Upper Pulley
    • VAP: Crank Pulley
    • VAP: Supercharger Belt
  • Symposer Delete
    • VAP: Symposer Delete Jaguar Range Rover Land Rover 3.0 AJ126, 5.0AJ133
  • Cooling System Upgrade
    • Coolant Overflow Reservoir Tank Compatible with Jaguar F-Type 2014-2021 [3.0L 5.0L], XK 2007-2009 [4.2L], XK XKR 2010-2015 [5.0L], XKR-S 2012-2015 [5.0L], Expansion Bottle with Cap Replace# C2P25607
    • VAP: Pierburg CWA150 Water Pump - 2015-on Jaguar/Land Rover AJ133/AJ126 3.0 5.0 Supercharged Engines
    • Euro AMP: 15-25 Jaguar Land Rover Cooling System Upgrade Kit V2 5.0 V8 Supercharged Engine × 1
BigJMaas
Jul 4, 2025 09:43 AM
JaguarXKR
Nov 19, 2013 03:04 PM
rothwell
Nov 29, 2010 04:22 PM
ron44094
Mar 3, 2010 04:04 PM
jjones91
Apr 22, 2009 10:43 AM
