About jaguar f type steering wheel swap to f pace steering wheel problem
Old Dec 6, 2022 | 04:25 PM
Cigar0812's Avatar
Default About jaguar f type steering wheel swap to f pace steering wheel problem
The f-type and f-pace steering wheels are different from The bottom. Are there any solutions that can fix it?
Old Dec 6, 2022 | 04:56 PM
Ftypess's Avatar
Where did you get the steering wheel?
Can be machined to fit? Drilled out?
Old Dec 6, 2022 | 05:13 PM
Cigar0812's Avatar
Someone tell me that I might have to change my F-type steering column to an F-pace steering column, but I don't know if it is going to work or not
Old Dec 6, 2022 | 06:03 PM
OzXFR's Avatar
I doubt that the electronics/controls will work and the wiring plugs look completely different.
Old Dec 6, 2022 | 09:02 PM
Borbor's Avatar
wouldn't it be easier to just get a replacement steering column for the f-type. if you have to replace it for what ever reason why put one in from a f-pace ???and then have to cobble it together. Makes no sense at all
Old Dec 7, 2022 | 07:01 AM
cujet's Avatar
Is the problem the steering shaft shape? Hex vs. Round?
I don't have a concept of how these things are made (probably cast aluminum), or what specific alloy they are made from. However, it seems that a mechanical adapter could be fabricated. And a little machine work performed. Maybe cut out a 2 inch hole and bolt in an adapter?
I am guessing you don't like the look of the F-Type's wheel and wanted something different?
Old Dec 7, 2022 | 01:09 PM
kevin_jag's Avatar
That looks like an aftermarket wheel on the left, integrated shift lights and some sort of LCD display.
Old Aug 23, 2023 | 10:30 AM
FJCoffee's Avatar
Hey did you ever figure this out and get it swapped??
@Cigar0812
Meyjka
Sep 2, 2022 05:26 AM
Wayne Lea
Jan 15, 2022 06:14 AM
Dave_Car_Guy
E type ( XK-E )
Nov 19, 2017 10:40 AM
Logotipo
Apr 20, 2012 12:17 PM
datekho
Jun 4, 2008 10:05 PM
