Adaptive dynamics not available
Hi folks
car displaying adaptive dynamics not available, fault code C1A04-2.problem came after car was lowered.?
just wondering if anyone came across this before.
Different model, similar problem...
https://www.jaguarforums.com/forum/x...8/#post1348835
The F-Type has height sensors connected to your lower control arm. They serve multiple functions, from providing the DSC a reading about the load on a specific corner to failsafe to AWD cars. When the senor reports a low height on AWD cars it goes as far as disabling AWD and go in 2WD to protect the shafts, on other cars it can and will disable dynamics.
Check the right front height sensor, or you simply lowered it too much
Aha, it's an SVR, that might explain the problem!
The SVR has some different suspension components compared to an F-Type R, and I think different calibration of the active suspension.
Had the car lowered with the shop that done the lister f type, the springs are the same as that which are the KW lowering springs, spoke with the chap at kw and he assured me they had the right ones. I think the only difference is awd & rwd.
Car going back to the shop later in the week. Anyone here had there svr lowered?
Quite common. Glad you are all set now.
I'm having the same fault code. What did they do with the height sensor?
My problem was just a loose connection on the ride height sensor
Aaron S
Jan 12, 2015 12:52 PM
