Air Vent stopped raising.
Old Jan 2, 2015 | 01:52 AM
zerphyte's Avatar
Default Air Vent stopped raising.
Anybody know how to manually raise the air vent? Mine stopped raising when I turned on the heat or ac. Not too keen on having to spend an hour or two driving to the dealer and waiting for them to look at it if its something stupid and easy.
Old Jan 2, 2015 | 04:05 AM
F-typical's Avatar
There's on option on the menu to have the vent permanently up.
Old Jan 2, 2015 | 04:06 AM
mawheele's Avatar
Hi there - this is a known issue and Dealers currently have a campaign to test and fix all F-Type. There is a test they have to run by checking the clutch mechanism for the vent assembly by placing the toe hook on top of the unit. If the unit rises then its passed, otherwise replacement parts takes 30 minutes.
Hope that helps.
Old Jan 2, 2015 | 10:38 AM
shift's Avatar
You mean when you turn off auto? You have to go in to the menu to tell which vents you want. You can slso change the temp sensitivity. I just discovered this yesterday.
Old Jan 2, 2015 | 02:24 PM
Unhingd's Avatar
From day one, the rising vent concept was a problem waiting to happen.
Old Jan 2, 2015 | 02:33 PM
Stohlen's Avatar
Which is interesting, because it is an extremely simple concept. Basically the same exact thing as a power window.
Old Jan 2, 2015 | 02:47 PM
Unhingd's Avatar
But on a smaller and more fragile scale.
Old Jan 2, 2015 | 05:02 PM
phillyweb's Avatar
The first time it came up I was like "oh that's cool", every single time since all I think is, one day that Will break, and I wonder how much all the stuff making it work weighs? Girls still think it's "neat" though.
Old Jan 2, 2015 | 05:49 PM
Unhingd's Avatar
Originally Posted by phillyweb
The first time it came up ...... Girls still think it's "neat" though.
I'm glad for you.
Sorry, couldn't resist.
Old Jan 2, 2015 | 09:23 PM
phillyweb's Avatar
I'm glad for you.
Lol it's cool. I get this sixth sense idiot chill thing every time it starts coming up.. "Oh god have they seen it before"? ... And then before it even gets all the way up... "Omg, wow that's so neat!" ... Nope she hasn't seen it before.
How spoiled are we that we complain about our ac vents raising out of our dash. Good problems to have indeed.
Old Jan 2, 2015 | 09:50 PM
Unhingd's Avatar
+1 We suffer sooo much!
Old Jan 2, 2015 | 10:11 PM
shift's Avatar
I also find it really annoying that the folding mirror motors make too much noise. They need to be a little more quiet.
Old Jan 2, 2015 | 11:39 PM
jmfan's Avatar
The temperatures have been in the 30 – 50 degree range here in N. California lately. I noticed the center vent in my car has not been rising in the colder temps. The heat works just fine and I assumed it was normal that the center vent was probably not needed for heating in colder temperatures in auto mode. It does work fine when the outside temperature increases.
Old Jan 3, 2015 | 12:14 PM
Foosh's Avatar
That doesn't sound normal. It's now routinely in the 10's and 20's in the mornings in these parts, and my vent raises and lowers with full heat pouring out. I leave it in auto-mode all the time.
Old Jan 3, 2015 | 12:36 PM
F-typical's Avatar
Hmm... My centre vent powers up and down if I play with the menu, but with the colder weather its been hiding. Basically it never gets warm enough for the aircon to kick in, so the vent doesn't pop up.
So there we have it: conclusive proof that low temperatures can affect your ability to get it up...
Old Jan 3, 2015 | 12:55 PM
Foosh's Avatar
Interesting.
I've never messed with any of the settings since taking delivery because the car's always been comfortable in auto-mode just by setting the temp. That's probably the difference, and why mine always comes up on start-up--hot or cold.
Maybe that's a good thing. It needs exercise, and I'd hate to have mine stuck down.
Old Jan 3, 2015 | 01:40 PM
Unhingd's Avatar
Use it or lose it?
Old Jan 3, 2015 | 03:10 PM
zerphyte's Avatar
Wow ok i'm an idiot! Yes that is it and I did just happen to accidentally knock the auto button before it stopped working. I can't believe I missed that in the menu I was looking on every other screen but the right one. Thank you!! Now its all fixed
Old Jan 8, 2015 | 09:54 PM
XFactoR's Avatar
How do you change the temperature sensitivity??
Old Jan 8, 2015 | 10:09 PM
shift's Avatar
press the climate button, then I think it's under setting.
