Airbag light is on
Old Oct 12, 2022 | 07:55 AM
Magbor123's Avatar
Default Airbag light is on
Hello!
I have an F-type 2016 which is imported from USA. When I bought it, the airbag light in the cluster did not light, but after a while it has started to light up. Not always but almost. At the rearview mirror in the roof it also says "passenger airbag off"
When I searched for instructions online to turn the airbag off/on, you can do it under Vehicle setting in the instrument cluster. But I don't have that choice and I can't find anywhere that it should be possible to disconnect it.
Some tips or ideas?
Have a good day!
Magnus
Old Oct 12, 2022 | 08:19 AM
DJS's Avatar
DJS
I wasn't aware you could manually switch it. There's a sensor in the passenger seat, and based on the weight it detects, it decides whether to enable or disable the passenger airbag.
Old Oct 12, 2022 | 08:34 AM
Magbor123's Avatar
Correct, I tried to sit down in the passenger seat and the light in the roof goes from "Airbag off" to "Aibag on" that working :-)
But the warning light in the instrument cluster is on...
Old Oct 12, 2022 | 08:34 PM
Thunder Dump's Avatar
That airbag warning in the cluster means one or more sensors are not working correctly--it doesn't indicate which one. The airbags will not deploy while that is lit up.
Old Oct 12, 2022 | 09:04 PM
OzXFR's Avatar
Agreed.
The only way I know to remove the warning light and get the SRS working again is to fix the sensor error then delete the error code, and the only way to remove an SRS error code is with the factory SDD tool.
Depending on where he is the OP may find that an SRS/airbag light on means an automatic fail of any roadworthy check, never mind that the SRS is completely disabled.
Jaggyx
39
Feb 3, 2023 06:50 AM
psyo
Sep 3, 2021 05:12 PM
pnyklr
Feb 7, 2010 11:51 AM
jmg7184
Jun 25, 2009 01:56 PM
apollo022777
Apr 16, 2008 07:56 PM
