Alignment adjustment points
Old Nov 13, 2016 | 03:25 PM
Mpowerr's Avatar
Default Alignment adjustment points
Hi all,
I believe camber, caster, and toe is adjustable in the front and only toe in the rear; is this correct?
Also where are the adjustments points for camber and caster in the front, and camber in the rear? Does anyone happen to have any pics?
Lastly what are the jag recommended specs for the R and SVR?
Old Nov 15, 2016 | 12:17 AM
Mpowerr's Avatar
no one???
Or has or been discussed before? I didn't see much but didn't spend too much time searching. Back to searching I guess...
Old Nov 15, 2016 | 04:58 AM
Unhingd's Avatar
Originally Posted by Mpowerr
no one???
You are correct: camber, caster, and toe is adjustable in the front and only toe in the rear. Knowing where the adjustment points are, is of no use unless you have an alignment machine in the garage. If you do, I'll pm you the alignment instructions.
Old Nov 15, 2016 | 11:16 AM
Mpowerr's Avatar
Not in the garage, but I do have access to on every from time to time. Can you please PM me those instructions!
Old Nov 15, 2016 | 11:47 AM
Unhingd's Avatar
pm sent
Old Nov 20, 2016 | 11:52 AM
XFactoR's Avatar
Default Can't get my wheel straight after dealer alignment
I think that not all dealers understand the intricacies of the F-Type alignment. I can't get them to get the wheel to be straight. Car tracks straight but wheel is a 3 degrees to the left. Annoying!
They have tried to address it 4 times!
Old Nov 20, 2016 | 12:54 PM
Unhingd's Avatar
It's not rocket science. Center the steering wheel, then align the wheels.
Old Apr 7, 2024 | 08:36 AM
Kuhli's Avatar
Hello everyone,
I came across this post through a search.
I was washing the Jag today and by chance saw that the left rear tire was more worn on the outside than the right side.
Can you set something there?
Thank you
Frank
TropicCat
Jul 3, 2021 02:52 AM
jehart49
Sep 9, 2017 08:33 AM
bfsgross
Oct 4, 2011 08:57 AM
phd12volt
Aug 7, 2009 11:24 AM
Thermo
Jun 30, 2009 07:07 PM
