Alternator Replacement
Old Sep 30, 2024 | 03:13 PM
RGPV6S's Avatar
Default Alternator Replacement
Anyone out there ever DIY an alternator replacement on an F-Type? Looks like doing it from underneath the car would be easiest. True? Any other tips?
Old Oct 3, 2024 | 07:25 AM
CarlB's Avatar
I haven't done it personally, but looking at the service manual it seems easy enough. Attached is a PDF export.
-Disconnect battery
-Remove undertray
-Remove serpentine
-Remove alternator
File Type: pdf
Old Oct 3, 2024 | 09:28 AM
uncheel's Avatar
No big deal, but do it on a lift.
Old Oct 3, 2024 | 01:22 PM
RGPV6S's Avatar
Thank you.
Old Oct 3, 2024 | 04:06 PM
NBCat's Avatar
To ensure the correct functioning of the system, have the alternator in the vehicle overhauled by a competent automotive electrical specialist rather than getting one off a shelf at a parts house.
Old Oct 3, 2024 | 07:12 PM
dennis black's Avatar
What makes you thi k your alternator is bad
Old Oct 4, 2024 | 08:38 AM
RGPV6S's Avatar
After driving for an hour or so battery voltage gets low - ~12.2 V. Charging voltage with engine running should be at least 13.5 to 14.5 V. With engine running stays at battery voltage and only briefly jumps into proper charging range every 2 to 5 minutes for about 30 seconds then goes back to battery voltage and keeps falling when I drive.
Note I keep the car on a CTEk all the time. Just put a new battery in the car about two or three months ago.
Old Oct 4, 2024 | 08:48 AM
Thunder Dump's Avatar
Could be a bad BCM module on the battery too, incorrectly fluctuating the alternator output.
Old Oct 4, 2024 | 09:36 AM
cujet's Avatar
I believe that's normal. Nearly all modern cars do this to improve MPG and prolong battery life. The charging is computer controlled. Are you getting a charging system warning?
Old Oct 4, 2024 | 11:01 AM
scm's Avatar
scm
Mine always shows above battery voltage when the engine's running. Sounds like the OP has a fault, either with the alternator or the charging circuitry.
Or could just be a dodgy earth - I had a company car decades ago and after every service the battery went flat after 4 days. I eventually traced it to an earthing strap that was bolted to the fan belt tensioning arm, which the tech managed to break (every time!) when they adjusted the belt tension. D'oh!
Old Oct 4, 2024 | 11:18 AM
samit's Avatar
Did you do a BCM reset after replacing the battery? Mine had very similar symptoms after a battery replacement, but a simple reset fixed it. At the very least I would check for any error codes before starting to replace components.
Old Oct 4, 2024 | 12:44 PM
RGPV6S's Avatar
How do you reset the BCM?
Old Oct 4, 2024 | 12:45 PM
RGPV6S's Avatar
No charging system warning.
Old Oct 4, 2024 | 12:46 PM
samit's Avatar
I used my iCarsoft LR code reader, but I'm guessing any Jaguar mechanic can also do it for you.
Old Oct 8, 2024 | 08:11 AM
RGPV6S's Avatar
This was the problem. Thanks for your suggestion.
BTW got to buy some new toys troubleshooting this issue. A battery analyzer, an endoscope and an ICarsoft LR V3.0.
Used the LR V3.0 to reset the BCM and the battery analyzer to make sure the new battery wasn't defective. I examined the alternator and timing cover with the endoscope to check for oil leaks and there were none.
Phil m
Jun 15, 2024 12:18 PM
Harry Peter Rose
Aug 8, 2022 05:37 PM
Harry Peter Rose
Aug 5, 2022 03:01 AM
petemohr
May 6, 2020 02:40 PM
bookman
Nov 10, 2014 10:17 AM
