anyone hear this noise?
Old Feb 4, 2016 | 11:15 PM
Frenchy's Avatar
Default anyone hear this noise?
It's a blend of a rattle and a rubbing sound. Not loud at all, just audible enough to be annoying. It seems to be coming from just behind my head on the left, maybe from the opening in the panel where the seat belt retracts. Only 3800 miles on the car.
Old Feb 5, 2016 | 08:16 AM
jm717's Avatar
I had an irritating sound that you can find more about in the middle of this thread: Rattling rear hatch cover - Jaguar Forums - Jaguar Enthusiasts Forum My sound recording is there too, so you can check if it sounds similar. Towards the end of the thread, you can see what the dealer did to fix it. May not the same as yours, but I thought I'd mention in case it is.
Please note that my sound issue and fix had nothing to do with rear hatch cover as the thread name suggests. I should have posted my problem in a separate thread but I didn't.
Old Feb 5, 2016 | 08:37 AM
ek993's Avatar
Coupe or convertible?
Old Feb 5, 2016 | 08:47 AM
Frenchy's Avatar
Default forgot to mention
It's a coupe. And I don't use the hatch cover.
Old Feb 5, 2016 | 01:11 PM
MI-FType's Avatar
Frenchy, I have a noise coming from the same spot. Kind of a light rattle... I heard it on on my '15 Base and I also hear it on my '16 R Coupe. I would love to get to the bottom of it. It's a little annoying.
Old Feb 5, 2016 | 01:17 PM
Frenchy's Avatar
Annoying indeed, MI-FType. And the only imperfection on an otherwise perfect car.
I'm not scheduled for service till the summer, and my dealership is not close. Do you plan on taking your car in to have them look at it? If so, could you please keep me posted?
I'm thinking it's something in the spring assembly that retracts the belt.
Old Feb 5, 2016 | 01:25 PM
MI-FType's Avatar
Could be... it does sound like it's coming from the belt assembly. It's not a constant sound though. I notice it more on small bumps.
I will mention it when I go in for my first service (late summer), but it hasn't bothered me enough to schedule a special trip.
Old Feb 5, 2016 | 07:11 PM
Lookout!'s Avatar
Is it possible that it's simply a directional illusion of the air intake by the steering wheel?
Old Feb 5, 2016 | 08:36 PM
Liamgo's Avatar
My '15 coupe makes that noise too. Sounds like plastic panels rubbing together by the seat belt reel.
Old Feb 6, 2016 | 02:03 PM
Frenchy's Avatar
Liamgo, has your service department taken a look/listen? If not, any plans to ask them? I'd be interested in what they say.
Old Feb 6, 2016 | 04:27 PM
Foosh's Avatar
No one seems to have paid attention to this post, but perhaps you should if you have a similar noise.
Pertinent post from jm717 below:
Just got my car back from dealer today, and they fixed this issue for me. All done as a warranty repair and I am happy to report that my squeaking/tapping sound is gone. What was done is below (excerpt from $0 invoice):
22293 BODY FLEX AT LEFT LOWER B PILLAR TO STRUCTURE FASTENERS TEST DRIVE WITH CHASSIS EARS ON LR SPRING, SWAY BAR, SHOCK, LOWER CONTROL ARM, & ROCKER PANEL, REMOVE TRUNK INTERIOR PANELS TO ACCESS SHOCK, REMOVE LOWER DOOR SILL CLADDING AND TEST DRIVE, LOOSEN B PILLAR FASTENERS AND INSTALL STRIP CAULK BETWEEN PANELS TO ISOLATE NOISE, TORQUE FASTENERS TO SPECS, TEST DRIVE, REPLACE LEFT DOOR WEATHERSTRIP
They located the problem and fixed it, so I'm a happy camper. I think it was in the area where b-pillar meets rocker panels. Just wanted to let you know that in case someone else experiences something similar.
Old Feb 10, 2016 | 08:18 PM
Liamgo's Avatar
Dropped it off on Friday for the noise among other issues. I'll let you know.
Old Feb 13, 2016 | 07:57 AM
akki05's Avatar
My 15 base coupe makes this noise too. I was at the dealer three times and they always said, they don't hear it. I really think they ignore it and simply hope I will give up.
I think they will win, because if you have heard three times that they have heard nothing
you give up because you feel like somebody who search a hair in a soup, as you know what I mean.
Old Feb 14, 2016 | 09:16 PM
OzRisk's Avatar
Yes, I had the same issue about 4 months ago. Had to take it back twice, but resolution was same as what Foosh has listed here. Warranty fix, no cost.
Old Feb 15, 2016 | 09:48 AM
Frenchy's Avatar
Liamgo, I'm just getting back to the forum after a few days away, so this suggestion probably comes too late. Anyway, my problem, and no doubt yours as well, are NOT from a rattling hatch cover. I don't use my hatch cover. The noise is from further aft, just behind left ear.
I'm hoping that the solution won't require major surgery, as the hatch cover problem did. I'd probably live with it rather than allow rhem to start removing panels.
What did your service techies say?
Old Feb 16, 2016 | 01:17 AM
akki05's Avatar
To make it clear. The noise in my base coupe has nothing to do with the hatch cover. It is
behind the left ear, exactly as Frenchy describes and even I think, it comes from the belt assembly. If somebody has found a solution of this problem, please keep us informed. As I wrote is my dealer no in the position to handle or fix it. Or, as I think, he just ignores it.
Thanks!
Old Feb 16, 2016 | 06:49 AM
OzRisk's Avatar
Thanks!
My problem was nothing to do with hatch cover, but was resolved by removing the interior trunk lining, reseating some fasteners, cladding with some vibration suppressing cladding and closing up again. Much like Foosh's report describes. The noise was like a buzzing vibration coming from right behind my right ear (I have a RHD car). I was almost certain it was to do with seatbelt assembly - it was not.
I concur with Foosh's earlier post - no-one seems to be paying attention to his solution to your problem, nor my last post.
Old Feb 16, 2016 | 06:53 AM
Foosh's Avatar
Thanks!
See posts #11 and #14. It's not coming from the seat belt assembly, but body flex at the B-pillar behind your ear. The thread linked in post #11 contains a sound recording, which will probably confirm that for you.
The fix is also known to JLR, and all you have to do is print and hand that to your dealer.
Old Feb 16, 2016 | 08:11 AM
pistol's Avatar
I have the exact same issue on brand new R Coupe, from 30 miles when I picked it up till now at 500 miles.
It's really annoying! Great car otherwise
Old Feb 16, 2016 | 12:48 PM
akki05's Avatar
Thanks OzRisk and Foosh. The sound recording you mean has nothing to do with the noise in my car but I will take a last try with my dealer. Would be nice if it works. If not, I will live with it.
