Article, F Type car reliability
Old Dec 17, 2024 | 05:17 PM
WSHudds's Avatar
Originally Posted by MajorTom
I wouldn't mind having a dipstick as a backup solution but never saw the need of one in these cars. I've owned different Jags for over a decade now, none of them had a dipstick and there was never an occasion when I wished I had a dipstick. Never needed to top up oil between services either. I don't mind getting my hands dirty and am pretty OCD about the condition of my cars but when it comes to the oil level I just expect the car to tell me in the unlikely event of something being wrong. I just don't get the point of manually checking the oil level of a healthy modern car in this day and age.
That said, did anyone ever have any issues with the oil level in their F-Type? The only cases I can think of are clueless dealers overfilling AWD cars by using the RWD oil amount when changing the oil but then the car tells you that it's overfilled.
Not having a dipstick for me is far from being a major issue. As you know, I prefer more analogue cars with a manual transmission, knobs and dials. I don't think much of the tech modern cars come with add value and, taking away the dipstick without at least implementing an oil temperature gauge is just annoying.
If you wait for the car to warn you about the oil level due to leaks or consumption, you could by then have driven many miles with much less than the ideal amount of oil leading to increased wear. And as I mentioned in a previous post to SCM, we just don't know what scale Jag used to design the electronic display.
As I daily mine, I inspect under the hood once a week for any signs of coolant leaks, check the coolant level, so I could do with a manual way of checking the oil level as well. I've tried to get to a reading by using the "pop the hood open, press Cancel twice" method but it just doesn't seem to work with my car so I have to drive, stop, wait 10 minutes to get an average reading instead. That doesn't sound like progress to me 😉
Ramart's Avatar
Originally Posted by scm
The article starts with a false premise - that the F-Type has never been a reliable car...
Actually, the article says the F-Type has "never been unreliable" - just the opposite of your mistaken impression.
It also calls the F-Type's NHTSA scores "very impressive..."
Old Dec 17, 2024 | 05:38 PM
Ramart's Avatar
did anyone ever have any issues with the oil level in their F-Type? ...
Yes, but only because of an overfill error with the final complimentary warranty service for my 2020 P300 (RWD) last April. I bought a syringe pump to extract nearly a quart through the dipstick tube after I discovered the error upon returning home, so I wouldn't have to drive 30 miles back to the dealership.
I know overfilling can be more dangerous than underfilling (up to a point), and I wonder whether they overfill intentionally so you'll return for new gaskets and seals after leaks develop? Or is this common failing caused just by negligence or poor training? I'm using independent mechanics from now on.
Turko
Dec 19, 2024 03:37 PM
Turko
May 17, 2022 01:11 PM
Turko
May 17, 2022 01:30 AM
JagXSE
Apr 29, 2021 04:53 AM
