Base exhaust - crackle and pops?
A base F-Type with the active exhaust?
Yes and no.
It will still crackle and pop, just not quite as much or as loudly as a car with the active exhaust in "loud" (exhaust valves open) mode.
And automatic is completely irrelevant, I have a V6 automatic with switchable active exhaust. It's just that the base V6 wasn't optioned with the active exhaust (passive or switchable) as often as the V6S was.
Same as what?
Yes and no.
Yes and no.
not huge but enough to make me get an aftermarket system if I had the passive exhaust, vs not really needing it with the switchable active.
I change my original statement, drove a manual coupe this weekend wiht switchable, still very muted and quiet on a coupe from the inside, all coupes need aftermarket exhaust lol, convertible does not
Yes, if you have non-switchable active exhaust, you can simply plug the vacuum lines to the valves. I did mine and plugged the valves themselves just to keep debris out. It is very easy to do with a couple short lengths of vacuum hose and anything to plug the hoses.
NiteriderSC
Aug 3, 2016 07:06 PM
