Battery shorting out? Car died suddenly
Old Feb 6, 2023 | 06:56 PM
tolson's Avatar
Originally Posted by NBCat
The age of a battery is meaningless. Report back once you've charged the battery.
What did your scanner show for fuel pressure?
In addition, check the fuse for the electrical fuel pump in the tank to see if it's still intact.
New AGM battery was charged to 13v prior to putting it in. The car does have the possibility of starting however it runs super rough and only stays on if I keep on the gas.
I have not checked the scanner for fuel pressure, I'm assuming the car needs to be running and to then run a live charting application on it?
Can I get at the fuse easily for the fuel tank? Or does everything have to be removed?
Old Feb 6, 2023 | 07:55 PM
OzXFR's Avatar
The high pressure fuel pumps on the AJ133 and AJ126 are a known failure point. Not all that common but they do fail from time to time once the mileage gets up there.
Two of them, low down on the right hand side of the block one behind the other, driven by a chain off the crank.
One of them failing is now my prime culprit.
Check out this AJ133 tear down by I Do Cars, it shows those fuel pumps a couple of times:
TheOne
Jun 15, 2017 09:09 PM
dennyhle
May 25, 2016 09:21 PM
AnD3rew
May 24, 2016 06:31 PM
anONYMOUSdroid
Jan 26, 2014 03:36 PM
Fedoraja1
Feb 25, 2011 07:57 PM
