Brake Dust
Old Nov 26, 2017 | 12:19 PM
911Königin's Avatar
Default Brake Dust
Hopefully, this has already been covered..............................brake dust is awful What have you found is the best way to keep it off?
Old Nov 26, 2017 | 12:36 PM
jbajor's Avatar
Nano coat your wheels then use Sonax to clean.
Old Nov 26, 2017 | 12:40 PM
RGPV6S's Avatar
Switch to Porterfield brake pads.
Old Dec 4, 2017 | 07:27 AM
SamtheSham's Avatar
What is the 'Sonax' you refer to? I thought I had seen most of the cleaners.
Old Dec 4, 2017 | 07:36 AM
jbajor's Avatar
Last edited by jbajor; Dec 4, 2017 at 08:54 AM. Reason: link did not post properly
Old Dec 4, 2017 | 09:37 AM
ShaunPA's Avatar
Sonax and other iron removing wheel cleaners do a great job of cleaning the wheels. Coating the wheels will again aid in making the wheels easier to clean. To minimize dust you have to change pads. The Porterfield R4S is the best option right now. The only other aftermarket pad out there right now is the the EBCs which are terrible IMO.
Old Dec 4, 2017 | 08:05 PM
Mbourne's Avatar
Sonax works well. Smells horrendous however so do yourself a favour and lock it away when stored somewhere the vapours can't escape.
Old Dec 5, 2017 | 09:06 AM
Greggbhill's Avatar
+1 on coating & porter field pads
I also used Sonax and it works great. I then found Griot’s Heavy Duty Wheel Cleaner and like it better. Doesn’t smell bad and it sprays on sudsy and covers better with less product. Results same as sonax, just my preference.
https://www.griotsgarage.com/product...eel+cleaner.do
Old Dec 5, 2017 | 09:13 AM
ShaunPA's Avatar
i've gone through about every iron reacting wheel cleaner on the market. the best value with least smell i've found is gyeon iron. carpro ironx lemon isn't bad but i had 2 bottles with major leaking/dripping problems, so i won't go back.
Old Dec 5, 2017 | 12:24 PM
Tman003's Avatar
Are these products safe to use on coated wheels?
Old Dec 5, 2017 | 02:59 PM
woodturner's Avatar
Sonax is safe to use on coated wheels. I can't speak to the others.
Old Dec 6, 2017 | 01:23 PM
911Königin's Avatar
Thanks so much for the info It seems to be getting better, but will definitely change out the pads when new rims are put on.
Old Dec 6, 2017 | 09:42 PM
Greggbhill's Avatar
Griots is safe too
