Brake Fluid Flush & Change
On a recent thread where I was locked out of my car because of a key fob issue, car is in the dealership at present, they are recommending that the Brake Fluid be flushed and changed because it is recommended that the car is 3 years of age, and should be changed every 2 years.
@ 28k miles, I really don't know if that is necessary, although my CPO Warranty kicks in December 12th and I do not want and issue that may arise with the brakes during the CPO if I don't have the system flush.
I am aware that some sort of breakdown in the fluid happens, because it was recommended with my Harley. It's just questionable because of the low mileage...to me.
Brake fluid absorbs moisture from the air, that is why there is a 'time' replacement interval rather than a mileage recommendation.
I change my daily driver's brake fluid every three years (clutch too, are you listening @Unhingd ? ) and on my other exotic that I track once or twice a year, that is flushed EVERY year. (Moisture can lead to boiled fluid in track usage)
I didn't get any records of BF changes with my '14 so I changed it.
Failure to replace BF can lead to ABS issues on modern cars. IMO its well worth it.
Magical (11-30-2018)
Received 2,184 Likes
JaguarXJ8L2005
03-02-2018 10:09 AM
jagosaurus
06-25-2013 12:06 PM
