Brake Package Specs
Old May 12, 2016 | 09:42 AM
Atomic's Avatar
Default Brake Package Specs
Does anyone have any further details on exactly who makes the various brake options for the F-Type? The official website and literature is annoyingly devoid of details. For example, I have the Super Performance Braking Package on my car - here's what the website has to say about it:
"The Super Performance brakes, featuring 380mm/376mm brake rotors, are fitted with red calipers for visual flair"
Does anyone know who makes this system? How many pistons in the front and rear calipers? Any further details?
Thanks!
Old May 12, 2016 | 09:55 AM
SinF's Avatar
Don't have any information you are looking for, but for anyone customizing the car - big red brakes are nothing short of spectacular.
Old May 12, 2016 | 10:25 AM
WhiteTardis's Avatar
Ask and you shall receive. I can't confirm who supplies the non carbon ceramic brakes (which is Brembo). But the technical specs are here:
Old May 12, 2016 | 10:51 AM
DJS's Avatar
DJS
Interesting - so the super performance have the same front but larger rear rotors than the high performance brakes (which I have.)
Big red brakes are cool, but not on a red car.
Old May 12, 2016 | 10:56 AM
Atomic's Avatar
According to that spreadsheet, they do - it also seems to indicate that the calipers are the same on all three options. If that was the case, what exactly would be the difference? The calipers are visually different on the three systems, so I think that spreadsheet is missing some info...
Old May 12, 2016 | 11:09 AM
Foosh's Avatar
If the "Super High Performance" brakes have any less than 4 pots on the front calipers, they aren't worth the money. Those come on $40-60K Mustangs, Camaros, and Corvettes.
Old May 12, 2016 | 11:20 AM
Atomic's Avatar
I'd be really surprised if they were any less than 4 - and for the rears, any less than 2. Especially with those large discs and a heavy car.
ShaunPA's Avatar
pretty sure they are 2 piston fronts and single piston rears.
i've been looking at some after market caliper options, but need to know piston area to size the calipers correctly. after that it's just a matter of having a shot fab up some brackets.
Old May 12, 2016 | 11:32 AM
Unhingd's Avatar
Originally Posted by WhiteTardis
I can't confirm who supplies the non carbon ceramic brakes...
, but I believe they are ZF (TRW) brakes.
Old May 12, 2016 | 02:18 PM
Atomic's Avatar
definitely TRW - there are several of the calipers up on eBay and they are labeled TRW...
Old May 12, 2016 | 03:13 PM
StealthPilot's Avatar
I think you can order them in other colors. When ordering an R you can have the same brakes with black calipers.
Old May 12, 2016 | 03:15 PM
Arne's Avatar
You can. I have an R in IRR with optional black calipers.
Old May 12, 2016 | 05:09 PM
mshedden's Avatar
Does the number of pots make *that* much difference when the options are 2 or 4? Presumably braking force is the approx. the same, assuming master cylinders are the same?
On the base, the larger super performance rotor/caliper should perform better than the standard base stock rotor/caliper by virtue of the larger diameter.
Looks like the difference between high performance and super performance lies in the larger rear rotors/calipers and not the fronts?
Old May 12, 2016 | 06:01 PM
Foosh's Avatar
Yes, larger disks should perform better than smaller, but 4 (or more) pots will provide more clamping power than 2. Holding disk size, vehicle weight, etc. constant, 4 pot calipers will produce shorter stopping distances than 2. You've doubled the number of hydraulic pistons, and the more piston area you have exposed to the fluid the more force is exerted onto the pad/disc.
Old May 13, 2016 | 01:08 AM
mshedden's Avatar
Not to labor the point BUT - a woman in high heels exerts more pressure per unit area compared to a woman in sneakers, HOWEVER, the total force exerted is the same in both cases b/c the force is due to the woman's weight, which is a constant.
Similarly, the fluid pressure in the brake system should be the same (assuming same master cylinder) no matter what calipers are on the ends of the lines - it doesn't increase because there are 4 pots rather than 2, but it IS spread more evenly over the back of the brake pad.
However, given that the brake pad backing is a relatively thick metal plate, I would opine that pressure distribution at the pad face would be essentially similar with 2 OR 4 pots or at least not vastly different with everything else remaining constant.
Regarldless of the pot count, you can get the super performance upgrade kit (as parts) for the base car for ~ $2700 consisting of 4 larger rotors, 4 calipers etc, which seems a fair price in the JLR universe - and possibly the only viable *available* upgrade for the base. Not so good a deal for the 'S' however as it already has larger front rotors and calipers.
Old May 13, 2016 | 02:28 AM
OzXFR's Avatar
The Super Performance front brakes are the same size as fitted to my XFR (380 mm) and they look identical from the outside (same caliper, same anti-rattle clip), so as my front brakes are definitely 2 pot I would guess the F-Type Super Performance front brakes are also 2 pot.
Old May 13, 2016 | 06:48 AM
Unhingd's Avatar
That is correct. They are definitely two pot brakes.
Old May 13, 2016 | 07:34 AM
Foosh's Avatar
You raise very good questions that piqued my curiosity, so I looked into it a little more. The info on 2 vs. 4 vs. 6 pot advantages/disadvantages is conflicting and all over the map.
The only consistent consensus I found was that "more pot" calipers are generally bigger and better at heat dissipation. That advantage would probably only be helpful in terms of keeping your brakes alive for longer race track sessions. They seem to make little or no difference in terms of stopping distances until brake fade begins to occur.
The same seems to be true of carbon fiber vs. conventional brakes. One review I found had the V6S w/ super performance brakes stopping from 60 in 106 ft. vs. 104 for the carbon fiber brakes.
I'd always accepted on faith that more pots were better, but after looking into it, that's not necessarily the case. The demand for them seems more driven by the "bling factor" than anything else.
Old May 13, 2016 | 01:39 PM
Unhingd's Avatar
The only consistent consensus I found was that "more pot" calipers are generally bigger and better at heat dissipation...
That was always my understanding. Heat dissipation is also the consideration for bigger brakes as well. Note: if the brakes are cool, even the smallest brake option can easily lock the wheels. It's not until there is repeated braking (and heat) or stopping from great speed (generating massive heat) that you notice a difference.
+1.
Old May 14, 2016 | 02:55 PM
mikelanzetta's Avatar
... the force is due to the woman's weight, which is a constant.
Constant, and underreported.
