Broken Visor Screw Cover
Old Nov 3, 2020 | 01:07 AM
takeapieandrun's Avatar
Default Broken Visor Screw Cover
I don't really know what to call this piece, but shortly after purchasing my car it fell off on the passenger extreme right side. I suspect the little plastic ledges that 'grab' might be broken as there is very minimal hold when pressed in hard. Maybe there's a trick to it I'm missing, lol.
Does anyone know what this piece is called? I might end up gluing it but would prefer a new one..
Old Nov 3, 2020 | 01:35 AM
OzXFR's Avatar
It looks perfectly OK to me, I can't see any broken or missing bits or tabs.
A few years ago I took these off so I could remove the sun visors to then remove the super annoying "airbag warning" stickers, and they went back on with zero problems. I reckon you should try again to clip it on.
Edit - on closer inspection I can see a missing / broken off tab on the top right of the second pic so you probably need a new one!
Old Nov 3, 2020 | 01:55 AM
Hmm, I've tried pushing really hard, angling it in, etc.. doesn't seem to stick.. I'll give it a shot again later. I've done trim removal before but this little piece has me beat, hahaha.
Old Nov 3, 2020 | 02:27 AM
Well I managed to halfway clip it from the back by applying a lot of pressure behind the visor, but it still hasn't clipped in all the way. The driver's side was loose on the front and I managed to clip it in 100%, but the passenger side must be somewhat warped as it just won't follow suit.. applying pressure to the front makes the back pop out and vice versa. Tried some pliers with cloth over them, no dice.
Old Nov 3, 2020 | 05:12 AM
scm's Avatar
scm
I had that exact issue the first time I used my driver side sun visor, shortly after picking the car up. I agree it looks as if it should just clip back but it needs to be replaced. My dealer did mine straight away.
Old Nov 3, 2020 | 02:00 PM
Rondog's Avatar
To answer your original question, it' s called a Sun Visor Cover. Right side looks to be part # C2Z12631PVJ Check with your dealer.
Old Nov 3, 2020 | 10:48 PM
Thank you. I'll ask the dealer what they can do about it.
jackra_1
Apr 23, 2020 02:52 PM
Aarcuda
Sep 8, 2019 07:49 PM
PeteK812
Aug 3, 2019 08:32 PM
Shotimer
Jan 15, 2016 09:26 AM
kblood
Jul 14, 2012 07:00 AM
