A/C vents not popping up!
Old Aug 7, 2021 | 04:54 PM
Soul23's Avatar
Default A/C vents not popping up!
Help! The A/C vents are not coming up when I turn on a/c. I have a 2017 Ftype R. It is so hot here in FL! I can’t get the car in for service until Tuesday! Is there a manual way to get those vents up ? Just in the meantime?
Old Aug 7, 2021 | 05:32 PM
sov211's Avatar
Did you look in the menu on screen where the vent action is controlled? Did you check the setting for floor, face and defroster air flow? You can set the system so that the centre dash vent is always open, but it just might be that the air flow settings need adjustment.
Old Aug 7, 2021 | 05:45 PM
scm's Avatar
scm
If it's hot, I'd expect the vents to raise - that's how I know spring is on the way in the UK after a winter when the vents stay shut. But it'd be a good test to set them to always open rather than Auto and see what happens.
Old Aug 8, 2021 | 11:21 AM
Soul23's Avatar
thank you, SOV211! It was on defrost. I have no idea how that happened….but I changed it and the A/C vents popped back up. Whew! Crisis averted!
Old Aug 8, 2021 | 12:50 PM
sov211's Avatar
So many perceived "problems" are not really problems at all. Modern cars like the F-Type are so crammed with electronic features and variable settings that our own lack of understanding, failure to consult the owner's manual, or simply forgetting (in my case) cause us to think the sky is falling...and let's not forget (memo to self) that the overwhelming majority of complaints about the electronics have their source in one thing: low battery voltage - even though very often the problem and its real cause do not appear to be related. Invariably, correcting the issue of battery voltage resolves the matter. In this case it was even easier!
Human nature being what it is, we immediately assume the worst, and very often we fall into the myth of Jaguar unreliability. The truth is that modern Jaguars are, in automotive terms, very reliable cars - every bit as reliable as their rivals, as this former but not yet fully recovered BMW owner can attest.
prolepsis
Oct 19, 2020 03:53 AM
nikmott
May 7, 2014 05:18 PM
JaguarXKR
Jul 16, 2013 10:24 AM
flyrr100
Oct 1, 2012 01:22 PM
