CAN issue no dash lights
Old Feb 18, 2021 | 10:19 PM
citadeltcs's Avatar
Default CAN issue no dash lights
Have a short somewhere on my HS CAN circuit, I have unplugged the ABS module to see if this is a fix, I have no CAN, I use the SDD software and it wont see anything, tested the resistance it is 120 ohms. Which modules should I be unplugging to isolate this? I bought a CJB and put in, nothing changes. This is on a 2017 F Type 3.0L X152.
Old Feb 19, 2021 | 07:48 AM
Rummy636's Avatar
If i remember correctly, total resistance should be 60 ohms, not 120. There is a break in your CAN somewhere. Do you have a picture of which module are offline via SDD? There is multiple CAN in vehicle.
Old Feb 19, 2021 | 11:28 AM
citadeltcs's Avatar
via the SDD all modules are offline. Yes you are this particular car has dual CAN, this is on the HS CAN I believe the resistors are 120ohm each and are in the CJB and the ECU. Just hoping that someone has had similar issues and knows where the best spot to troubleshoot start is.
Old Dec 5, 2022 | 05:20 PM
citadeltcs's Avatar
Resolution was seat modules need to be connected for can voltage to pass.
Rchuda
Dec 29, 2020 06:28 PM
mickvic
XJ40 ( XJ81 )
Nov 6, 2020 06:49 PM
brinny
May 3, 2020 02:31 AM
Jaggy Jag
Oct 7, 2013 07:17 AM
