XJ40 ( XJ81 ) 1986 - 1994
dash lights
Old Nov 6, 2020 | 05:58 AM
mickvic's Avatar
Smile dash lights
All dash lights areout...any ideas where to start with that
Old Nov 6, 2020 | 06:09 AM
jimbov8's Avatar
A little more information wouldn’t go amiss.
Does the engine start? If it does, does everything else still work?
If it doesn’t start or crank then try the battery first.
Old Nov 6, 2020 | 06:39 AM
jerry_hoback's Avatar
Do you have a fuse out? Is the column knob turned to "off?" Maybe a ground wire needs cleaned up?
Old Nov 6, 2020 | 07:48 AM
mickvic's Avatar
car starts all gauges work just no lights illuminating instruments/dash at night
Old Nov 6, 2020 | 05:44 PM
mickvic's Avatar
where is the fuse?
Old Nov 6, 2020 | 06:49 PM
I 'think' its second from the left in the center console fuse box. However, there is an indicator lamp on the left side of the instrument panel, if there is a fuse blown it lights- looks like a lightning bolt. I don't have my owners manual at hand, but I know it lists them all pretty thoroughly. You can also look in the pages from the Haynes manual up in the sticky section.
brinny
May 3, 2020 02:31 AM
worzella
Oct 26, 2019 11:14 AM
ponceinlet
General Tech Help
Mar 13, 2013 07:35 AM
