Can you charge the battery from the jump posts in the engine bay?
Old Nov 7, 2022 | 09:21 AM
Whatsnext's Avatar
Default Can you charge the battery from the jump posts in the engine bay?
I just got a new battery in December last year. From time to time I was "thinking" I was charging the battery from the jumper posts in the engine bay since I didn't invest in a Ctek. Well the battery only made it until the beginning of November and needed to be replaced. It only ran me $7 to swap at Costco but I would have to assume then that the posts do now allow the battery to charge? And maybe now it is time to invest in a Ctek.
Old Nov 7, 2022 | 09:27 AM
RGPV6S's Avatar
I have been doing this for 6 years with no issue. However I do use a CTEK.
Old Nov 7, 2022 | 09:55 AM
Whatsnext's Avatar
I wonder if by change I am not using my charger correctly then. I thought I have been doing it properly and it never seems to take a charge. My booster/charger always shows 100% like it isn't needing to take a charge.
Old Nov 7, 2022 | 04:28 PM
OzXFR's Avatar
Almost ditto.
I have been maintaining my battery (the original) via the engine bay charging posts for over eight years now and it is still going strong.
Not a CTEK, a different 15 amp 7 stage tender/charger.
About five years ago I hard wired the connections to the charging posts so I simply have to plug the pigtail in, takes 10 seconds flat to connect, I have a thread with pics around here somewhere.
Old Nov 8, 2022 | 03:56 AM
dibbyandco's Avatar
As above, perfectly ok to charge from the posts. I wonder however if your battery "died" so early in it's life because of the dreaded OB11 issue? If it was constantly draining it would explain some of your issues.
Old Nov 8, 2022 | 09:46 AM
Valerie Stabenow's Avatar
Originally Posted by OzXFR
Almost ditto.
I bought the Ctek and used the accompanying eyelets to semi-permanently install it to the main AGM battery, as recommended by my JLR tech. As mentioned, there are several threads about connecting tender/chargers to the AGM.
Old Nov 8, 2022 | 01:28 PM
jcb-memphis's Avatar
Ditto.
UltraPeepi
Feb 23, 2026 08:34 PM
Lothar52
Dec 10, 2022 03:10 PM
gmsclassics
Jan 27, 2018 11:20 AM
ek993
Jan 7, 2018 07:19 PM
brgjag
Oct 31, 2010 07:03 PM
