Carbon Ceramic Rotors Needed
Old Apr 3, 2019 | 12:02 PM
markeverett's Avatar
Default Carbon Ceramic Rotors Needed
Does any know where I can get a set of Carbon Ceramic Rotors in the UK for my F type at reasonable cost - New or used... I am collecting a kit of parts to undertake the retrofit project and am now needing the rotors. Any thoughts or ideas welcome.
Old Apr 3, 2019 | 06:41 PM
OzXFR's Avatar
Probably not a good idea to get used ones unless you have 100% proof they were barely used.
I usually find that the cheapest UK seller of F-Type parts is Britcar, but even their prices for these rotors are ridiculous.
3455 GBP plus 691 VAT = 4146 GBP EACH for the front rotors (part # T2R13428) and 4042 plus 808 VAT = 4850 GBP EACH for the rear rotors (part # T2R23861) = a total cost of near as dammit to 18,000 GBP without factoring in any postage cost.
It seems you would be better off getting them from a US seller such as Jaguar Reno Parts even allowing for a large postage/shipping cost, for example see here: https://parts.jaguarreno.com/oem-par...rotor-t2r13428
I suspect that F-Type CCM brakes and "reasonable cost" are mutually exclusive terms.
Old Apr 3, 2019 | 10:27 PM
Unhingd's Avatar
The conversion cost as well as ongoing maintenance costs really make this an ineffective upgrade. Consider instead the installation of a set of Wortec Sunburst 2pc. rotors. That's about a $2800investment, a weight savings equivalent to the CCBs, and more heat dissipation than the OEM steel rotors.
rotors/discs
https://www.jaguarforums.com/forum/f...6/#post1939142
Old Apr 4, 2019 | 01:09 PM
beemarman's Avatar
https://www.ebay.co.uk/itm/Jaguar-F-...53.m1438.l2649
Check the link above.
Old Apr 4, 2019 | 05:36 PM
Unhingd's Avatar
Originally Posted by beemarman
A lot of pieces and parts still needed to attach those calipers, but still a great deal if they are in good condition.
Old Apr 5, 2019 | 03:49 AM
usgpru27's Avatar
General Motors uses Brembo rotors on the Corvette and Camaro. If you reasearch you will see that they are very close to the Jaguar rotors. Below are 396mm X 36mm vs 398mm X 38mm for the jag. These variances as I see it have no effect on the figment. Issue for you is that you need the Jaguar Hats to swap just the disk over. $1,200 US. This will be the direction I go if I need to do any replacement.
2015-19 Chevy Corvette Z06 Front Carbon Ceramic Rotor 177-1175 20981825
IronMike
Feb 17, 2016 11:24 PM
Benz2Jaguar
Aug 19, 2015 09:23 PM
SoCalJagS
Mar 7, 2015 01:55 PM
Unhingd
Jan 12, 2015 06:22 PM
rscultho
Dec 30, 2012 09:58 PM
