cargo cover
Old May 29, 2023 | 07:14 PM
ftypemaniac's Avatar
Default cargo cover
Hi everyone,
I have a 2018 F-Type and the back cargo cover has always had issues. Even after it was replaced it continues to "fall off" on one side or the other. I'm just wondering if anyone else has experienced this and if there is an easy fix.
Thanks very much!
Nick
Old May 29, 2023 | 08:17 PM
TH3FRB's Avatar
Originally Posted by ftypemaniac
Hi everyone,
Thanks very much!
Nick
Yup - common. There is too much "slop" and the pegs aren't long enough. I put a zip tie on eacg peg to take up some space and keep the cover from having a much side to side movement.
Old May 29, 2023 | 09:18 PM
Pupilbone's Avatar
I believe this to be a well documented issue, with supporting YouTube videos to boot. I’m sure you’ll tidy this up soon!
Old May 30, 2023 | 03:55 AM
scm's Avatar
scm
JTB00618 - parcel shelf loose or adrift. The "fix" is to fit a grommet each side to stop the side slop, p/n T2R35506. Should be done under warranty, if you have one.
Old May 30, 2023 | 10:45 PM
jcb-memphis's Avatar
If you don't have a warranty, I measured the peg (forget the size now) and got some rubber washers of the proper size (innder diameter) in black rubber....two or three on each side of the car on the peg, then put the shelf back on...voila, no wiggle and no falling off. Same idea as all of the above....3 dollars.
Caliper for about 15 seconds (or try a metal washer or two for size, ruler, whatever. Then at least here off to the web (amazon) and then it shows up the next day or so.
Heck, even if you have a warranty, not worth the time or gas to deal with it at the dealer.
SteveHall
Dec 21, 2021 09:41 AM
ArnettsJag13
Sep 24, 2021 10:37 AM
vet4scuba
Mar 30, 2020 01:58 PM
dblahnick
Jul 13, 2017 08:34 AM
Stu 1986
Jun 8, 2010 01:55 PM
