Center Grille Bar Replacement
Old Nov 23, 2021 | 03:44 PM
Rondog's Avatar
Default Center Grille Bar Replacement
On my newly purchased 2017 Coupe, the previous owner lived in a state that required a front license plate. SO now I'm stuck with 4 holes in the center bar. I have already ordered a new bar as it shows it as a separate item from the grille. Does anyone have any experience removing just this bar? Does the whole front end have to come off or can you get it from underneath the car after removing the bottom panels? I've seen the write ups for removing the grille to replace it with the P7 grille. Not going that route at this time.
Old Nov 23, 2021 | 04:22 PM
OzXFR's Avatar
Discussed elsewhere but I am 99% sure the grille has to come off to change the bar and the only way to remove the grille is to remove the front bumper.
So yes "the whole front end" has to come off which apparently (I have never done it) is not that difficult.
Old Nov 23, 2021 | 04:50 PM
Therock88's Avatar
Hi...Yes, the bumper cover will need to be removed to get to it. If you have parking sensors, you get to them from behind as well...Lots of fasteners, etc., But honestly about a 20-30 minute task.
Here is the process for removal/install (All variants - front and rear). Hope it helps. LINK HERE
DC
A photo of the underside for reference also...
Old Nov 23, 2021 | 07:14 PM
Rondog's Avatar
Thanks for the picture and link. It will surely help. I'm sure I'll stretch this out for more than 20-30 minutes. The car is put up for the winter. Got to find something to do over the next 5-6 months!
Old Nov 23, 2021 | 08:22 PM
Therock88's Avatar
Do what I did...Winter project Bought a Raptor...Added Water Methanol Injection, Bigger Intercooler, Cobb Custom Tune, Transmission Tune....and more. Going to add an intake, and exhaust next before it gets tooo cold Got it to about ~600 BHP. It's a beast. Good (matching) companion to the F-Type.
Take care,
DC
Old Nov 24, 2021 | 10:06 AM
TX69XKE's Avatar
If you decide to tackle this project to remove and replace the center bar, drop me a PM. I purchased a new center bar direct from Jag in the UK before I learned about removing the whole bumper assembly. Since I need to run a front plate, I've decided that it isn't a priority. I'll make you a great deal on the center bar piece and it is brand new and unmolested.
Old Nov 24, 2021 | 10:18 AM
Rondog's Avatar
PM sent. Thanks for the offer!
Old Nov 24, 2021 | 10:26 PM
Therock88's Avatar
FYI Rondog...You do not need to remove the headlight washers unless you are servicing them...Just disconnect the hose and leave them in place.
DC
Old Nov 25, 2021 | 10:10 AM
GeDaJew's Avatar
I have a 2017 convertible BDE. It came from Massachusetts with front plate holder attached. I removed the holder and simply plugged the holes.
Looks fine to my eyes. Sure, I would prefer a cleaner look I guess, but to me it's fine.
Old Nov 25, 2021 | 11:49 AM
scm's Avatar
scm
Originally Posted by GeDaJew
... I would prefer a cleaner look I guess, but to me it's fine.
That's all that matters!
Lovely looking car, too.
lpf4
Dec 19, 2020 11:46 AM
El Gato
Nov 29, 2017 03:00 PM
BodmanRae
Dec 4, 2016 07:51 AM
mshedden
Jul 9, 2016 11:12 PM
Beav
Aug 16, 2013 04:30 PM
