charcoal canister location
Old Jul 15, 2025 | 09:37 AM
ARDE's Avatar
Default charcoal canister location
Hi Everyone! I got 2014 Jaguar F-Type x152. I need to change my charcoal canister but I couldn't find where it is. Is there anyone who can help me where it is?? Thanks in advance !!
Old Jul 15, 2025 | 09:47 AM
OzXFR's Avatar
From the Repair Manual, quote:
"The EVAP canister is located in a central position, on top the fuel tank."
Looks to me like the only way to access it is to drop the fuel tank.
Old Jul 15, 2025 | 10:10 AM
DJS's Avatar
DJS
P. 4790 of the Workshop Manual shows that the canister can be accessed through the bulkhead behind the seats, without dropping the tank…
https://www.dropbox.com/scl/fi/o6d1x...=n4oayhev&dl=0
Old Jul 15, 2025 | 02:03 PM
ARDE's Avatar
Thank you for your quick response! I tried to access through the bulkhead behind the seats and I was able to replace from there easily.
Old Jul 15, 2025 | 02:14 PM
ARDE's Avatar
Thank you so much for your answer. I did exactly what you said.
Old Jul 15, 2025 | 02:17 PM
DJS's Avatar
DJS
Those are awesome pictures. At some point, I need to replace my fuel level sender, and this makes it clear how access works. Thanks!
Old Jul 15, 2025 | 02:18 PM
DJS's Avatar
DJS
Nice color too.
Old Jul 15, 2025 | 02:38 PM
farm-jag's Avatar
Just to throw this out there because I am not sure how many people know this or not (and certainly not assuming this was what was wrong with yours), but "topping off" the fuel tank after it has naturally clicked off because of being full, you know..to get to that next equal dollar amount, is often a cause of EVAP canister problems.
Old Jul 16, 2025 | 09:42 AM
F-type-r-2022's Avatar
WHERE ARE THE ROLL HOOPS???? Are they just cosmetic???
Old Jul 16, 2025 | 09:55 AM
ARDE's Avatar
I had to remove the roll hoops and speaker covers to access the canister. After I replaced the canister, I put them them back.
Old Jul 16, 2025 | 10:05 AM
How solid were the hoops and do you think they could hold the car up after a crash?
Old Jul 16, 2025 | 11:05 AM
DJS's Avatar
DJS
You might find this thread interesting.
https://www.jaguarforums.com/forum/f...-hoops-233984/
Old Jul 16, 2025 | 11:37 AM
Lots of fake news in that thread: Notaby, the photoshopped convertible windshield frame that is crushed and in the next photo it’s straight etc.. Corvette soft tops were all supposedly made with thicker wind frames for rollover protection. The C8 hardtop convertible seems to use the same technology.
Old Jul 18, 2025 | 07:31 AM
CarlB's Avatar
You can find Corvettes that are flattened after a rollover over on the CorvetteForum racing subforum. It's always a non-zero risk when rolling something without a cage combined with high energy roll-over.
I expect a rollover in my Corvette to be fatal or life altering without one of the many available roll bars or partial cages. Even with one it will be marginal due to the speeds.
Old Jul 20, 2025 | 08:43 AM
Dionysus's Avatar
This is absolutely true.
The vapor canister is to absorb fuel vapors that are emitted from the fuel tank. It is not meant to take on actual liquid fuel. Liquid fuel will quickly over saturate the carbon in the canister and will render it wasted and unable to absorb vapors.
I'll show a pic of another car (in this case, happens to be my Aston DB11), but the same system, same type of layout. This is a view of the filler neck. The small pipe with the arrow goes to the canister. Vapors will travel through this tube with a completely sealed fuel system. You can see, that if you keep topping off the tank after the first click, eventually liquid fuel will fill the neck and the small vent tube will actually be "under water" so to speak. Now, all that liquid fuel in the neck will end up in the canister.
Many cars today will have a warning sticker on the fuel lid. On my AMG GTS, for example, the warning to not top off. Many say stop at the first click.
On my Aston:
Old Jul 21, 2025 | 10:14 AM
This is great information BUT, for some reason, at certain gas stations (Costco for example), the gas always cuts off too soon but only in the F Type requiring a refilling that may overfill sometimes. Having read this thread, I will just get the shortage from Costco and get the rest at Chevron.
Old Jul 21, 2025 | 10:20 AM
clubairth1's Avatar
Community Influencer
Boy are you F-Type guys lucky!!
On my XJ that stuff is above the read diff/sub-frame and is a royal pain to get to for anything! You can hardly even see the assembly with the car on a lift!
PATRICK78
Jul 16, 2024 08:05 PM
AlexE
Jun 5, 2023 11:07 PM
nicolaimoeller
Jul 26, 2021 06:25 AM
Scott Bourne
Jun 3, 2013 07:06 PM
Jaguar Forums Editor
May 23, 2013 07:00 AM
