chirpy squeak in front end
Old Mar 29, 2020 | 08:00 PM
BruceTheQuail's Avatar
Default chirpy squeak in front end
Hi. I have a chirp somewhere in the front end that I can hear at low speed. Seems to be road surface related (i.e. from bumps), it is more of a chirp than anything, like you used to get in an old school bus going over bumps. Not sure if plastic or metal.
I had my tyre guys put it on a hoist and they did things but it hasnt gone away. Has anyone diagnosed something similar?
Old Mar 29, 2020 | 08:11 PM
OzXFR's Avatar
Never had that problem myself but it sounds to me like a front tyre could be rubbing on the wheel well lining.
If this is the cause you should be able to see rub mark(s) on the wheel well lining.
If you can't find any such marks then maybe find a suitable bump and helper, then get the helper to watch and listen as you drive the car over the bump.
Edit - there is a faint chance the chirp is due to one of the engine bay brace bolts being a little loose, see here: https://www.jaguarforums.com/forum/f...7/#post2210568
You need a Torx T50 to check/tighten them.
Old Mar 29, 2020 | 11:45 PM
devmen's Avatar
I have had this since my purchase, and I can't reproduce it reliably. I asked the dealer to take a look at it, so they look it out drive and could not "find anything out of the ordinary for an F-Type". The nice mechanic said because of all the plastic bits in the F-Type, you are going to have noises. Would will take a look at the bay brace bolts!
Old Mar 30, 2020 | 06:47 AM
Carbuff2's Avatar
Can't help you specifically (the above suggestions are good)...If it were me, I'd put it on a 4 post lift and hang/bounce from the support braces to try and duplicate the chirp with the engine off. I'd look carefully at the sway bar drop links, those can make noise with only a smidgen of looseness.
Now you guys know why my oil change regimen is to spray silicone on every rubber bushing I can find while the oil is draining (from the sump bolt). As my cars get older, I sometimes use a grease gun with a needle fitting to inject lubrication into ball joints and tie rod ends that don't have grease fittings.
The above predicates that you haven't mislaid a Rubber Ducky or Squeaky Dog Toy somewhere inside your F.
Salu498
Jul 12, 2017 05:09 AM
Cherry_560sel
May 21, 2016 07:44 AM
mrobinson
Aug 27, 2014 06:43 AM
chknhwk
Nov 18, 2010 07:13 PM
QuadManiac
Apr 6, 2010 05:54 PM
