Clunking at low speed
Old Aug 27, 2014 | 05:01 AM
mrobinson's Avatar
Default Clunking at low speed
I've got a fairly loud clunking problem in my 1998 XK8. I've had it to the mechanics and they can't find anything wrong.
The noise seems to be only related to speed changes, going over bumps doesn't trigger it. As far as I can tell, it's only caused by braking or accelerating, and it only happens at low speed.
It sounds to me like it's coming from the front somewhere, but I can't work out where.
Any ideas? It's pretty annoying.
Old Aug 27, 2014 | 05:43 AM
flatsix's Avatar
had a similar issue on another car recently, clunking appeared only on load changes. turned out it was the toothing of the length compensation of the drive shaft.
Old Aug 27, 2014 | 06:43 AM
mrobinson's Avatar
Do you know if it's a big job to get at the drive shaft to inspect? Any idea how much it would cost to fix, if that's the problem?
Forcedair1
Feb 19, 2020 01:51 PM
Razor
Aug 28, 2019 08:34 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
Johnken
Sep 15, 2015 05:46 PM
hen555
Sep 7, 2015 11:13 PM
