Convertible mesh wind blocker works well...?
Old Jun 2, 2018 | 05:23 PM
NavyBlue's Avatar
Default Convertible mesh wind blocker works well...?
Need current convertible owners' opinion on this.
I picked up my 2017 convertible on late Sat afternoon, at out of state dealership. Dealer says their derive dept techs aren't avail to install the factory mesh wind blocker, that I need to have my local Jag dealer install during the week. They even offered to pay an hour's time for it.
However, I've been driving around with vert down for past few days, & haven't felt that there's much wind nor wind noise. So wondering if it's worth even going thru the effort to have the factory mesh wind blocker even installed, since I don't want to mess with the clean look & possibly visibility to the rear.
Thoughts...?
Old Jun 2, 2018 | 05:36 PM
ek993's Avatar
I noticed a difference with it installed. It’s really easy to install, you could do it yourself.
Old Jun 2, 2018 | 06:48 PM
DJS's Avatar
DJS
I like it. It does reduce visibility a bit via the rear-view mirror. Very easy to remove and replace, once you have the brackets installed.
Old Jun 2, 2018 | 10:02 PM
bjg625's Avatar
Anyone can put in or remove. Go look at Windrestrictor first, clear! Everyone that has it raves about it, this is my second car to have it.
Old Jun 2, 2018 | 11:48 PM
jbajor's Avatar
It really works great! Excellent accessory!
Old Jun 3, 2018 | 10:45 AM
yugwmb's Avatar
Hmm. I may be one of the few people that couldn't really tell a difference with it in or out. Wound up leaving it out since I think the car looks better. I also looked into Windrestrictor but never pulled the trigger on it. I think wind and noise is something I just figured is part of the convertible experience! Atleast it's quieter and less windy than my '95 Wrangler!
Old Jun 3, 2018 | 02:29 PM
Buckingham's Avatar
By all means install it. It is easy. You need a torx screwdriver(25?). Follow directions to remove small chrome insert. Pull the bottom edge out with a guitar pick and slide down. It comes right off. Position the bracket and screw in two captured torx screws on each side. Pop the tops and slide in screen. Make sure to only push down at edges and snap top in at both sides. This thing works great. At 95 mph with the top down, windows up, there is no draft. Very little affect on viz and at night, it seriously cut down on glare. I was going to put in a plastic screen but why bother. This is perfect as it is.
Old Jun 4, 2018 | 07:26 AM
Itismejoshy's Avatar
the screen is worth installing if your doing top down highway speeds, but it makes using the center mirror at night somewhat difficult.
Old Jun 4, 2018 | 08:04 AM
Unhingd's Avatar
Someone on this forum had a piece of tempered glass cut to shape that slides into the OEM brackets. Worked extremely well as a windscreen, did not vibrate and offered full visibility. If I had the vert, that's what I would do.
Old Jun 4, 2018 | 08:17 AM
SinF's Avatar
I took mine off, as I like maximum wind all the time. I very occasionally install it for long road trips and it does work well with windows up.
I don't understand what is there to install, it is two clips.
Old Jun 4, 2018 | 10:05 AM
Buckingham's Avatar
If you didn’t buy it installed, the clips are not there, just a chrome piece.
Old Jun 7, 2018 | 02:27 AM
Greggbhill's Avatar
That was me... took the mesh screen to a local glass shop and they traced it for a template. About $120 - better than mesh at night, and plexiglass because it doesn’t shake/wiggle.
https://www.jaguarforums.com/forum/f...6/#post1759349
https://www.jaguarforums.com/forum/f...-noise-179079/ See #16
Old Jun 7, 2018 | 09:47 AM
NavyBlue's Avatar
Great idea.
I didn't want to use the factory mesh WindBlocker since I didn't want to cut down visibility, & also didn't want to spend another $350 for a WindRestrictor.
I'll check out local shops for tempered glass...
Old Jun 7, 2018 | 09:53 AM
dws009's Avatar
Personally, I like it! Yes, there's a small loss of visibility at night but it also helps to reduce the headlight glare from SUVs and trucks behind me.
Old Jun 7, 2018 | 10:02 AM
DJS's Avatar
DJS
The downside is that it makes it hard to tell if it's a regular car in the distance behind you, or a trooper. Sometimes, that's good to know...
Old Jun 7, 2018 | 10:41 AM
Mbourne's Avatar
+1. I've had that fear several times. But came to the conclusion that if I can see him behind me it's likely already too late
Old Jun 7, 2018 | 10:49 AM
dws009's Avatar
That is true but that's also why I have the Passport Escort 360 radar detector which has saved me many times!
Old Jun 7, 2018 | 11:01 AM
NavyBlue's Avatar
My wife ran off with a cop a few weeks ago.
So if I see flashing lights behind me, I'll floor the gas pedal to get away, afraid he wants to chase me down to give her back...
apachegogo
Apr 24, 2018 05:15 AM
emgun
Mar 22, 2015 10:39 PM
aahmichael
Jun 21, 2012 12:17 PM
Anticitizen
Dec 7, 2011 06:11 AM
sirpatrickhall
Oct 22, 2008 12:27 PM
