Creaking When Turning Right?
Old Nov 24, 2021 | 04:53 PM
Pistondrift_'s Avatar
Default Creaking When Turning Right?
I had my catalytic converters replaced last week at 28k miles (15 R) under US Federal warranty. Things were fine for the first 20 miles or so, then I noticed that the car makes a heavy creaking noise when transferring weight away from the front-right corner.
Does anyone know what they might have done to cause this? It sounds very similar to the time that one of the under-hood braces came slightly loose but after some inspection, those appear to be tight. My biggest fear is that they disturbed some panel adhesive while lifting it but perhaps there's a subframe brace loose that had to come off to replace the catalysts? Seems like this car wants to spend more time at the dealer (cats took almost a month to replace)
Old Nov 24, 2021 | 08:17 PM
BruceTheQuail's Avatar
Make sure they put the wheel nuts back on tight. I had the creaking after a service, it ended up the nuts were barely finger tight. I then got creaking again and it was a bearing gone which I suspect was a result of the first issue.
Old Nov 24, 2021 | 08:24 PM
Unfortunately, that was my first thought as well and they were on full German (gütentight!). It sounds like something is binding. I can induce it my turning right while stopped then unwinding the wheel as I pull forward.
Old Nov 25, 2021 | 06:14 AM
davidmaria1's Avatar
It may be a bushing. My guess is that the car was lifted at the pinch points and the suspension was "fully extended", so to speak.
Old Nov 26, 2021 | 02:25 AM
Therock88's Avatar
They should not need to remove wheels to change Cats/ downpipe, so would not think wheels were disturbed. The front cross member support gets removed and may not have been tightened properly, heat shields could have been removed/altered, and the midpipe section hovers right over a small support piece and if the pipes move down even 1/8 inch, it can rub.
Take a look at the pics in my DIY, and maybe will get some ideas? Link here
Good luck,,
DC
Old Nov 29, 2021 | 10:26 PM
schuss's Avatar
Check that the front crossmember support and the top of the shock mounts are tight, that was my creaking noise when turning right and it slowly progressed to a clunk as it got looser over time, until my independent shop found it.
Old Aug 6, 2022 | 08:56 AM
Sultan1966's Avatar
Just went through something familiar. 2 of 4 front strut bolts were loose on one side. All well after they were tightened.
RawwR
Apr 14, 2020 12:25 AM
WhiteTardis
Feb 22, 2020 09:26 AM
gkubrak
Nov 1, 2018 02:56 PM
Tahoe Dave
Oct 30, 2012 05:07 AM
Alag
Jun 9, 2012 04:38 AM
