Cylinder Head Issue
Old Feb 9, 2026 | 02:50 PM
Kyle L's Avatar
Unhappy Cylinder Head Issue
Hey everyone, I have a question about my 2015 F-type 3.0L Supercharged V6 ~47,000 miles
I drove my car to the Jaguar/Land Rover dealarship where I live to have a basic diagnosis done to figure out why my car was having a clicking noise when I drove (turned out to just be a loose break pad or something). However after their diagnosis they proceeded to do work on the engine bay, and while trying to extract the fuel injectors they told me that the injectors were very corroded (likely due to excessive water intake).
As the mechanic was trying to extract the injector they ended up cracking the cylinder head (I’ll try to post some pictures of it). Jaguar is claiming that they don’t have to cover the repairs because of the corrosion and sent me back with an undrivable car.
Most local mechanics in my area are saying it will need a whole new engine, and another local mechanic says that it could be 50/50 repairable but he’d need me to tow it to his shop to get a better look.
The car has about 47000 miles, I’ve only put about 1500 miles on since buying it.
My question is has anyone else heard about this situation, and advice on how to go about it, seeing as I don’t have money to buy another engine.
I can also attach more pictures if need be.
Old Feb 9, 2026 | 03:44 PM
WSHudds's Avatar
Really sorry to hear that. Why did they need to work on the injectors though? Did you sign any waiver before the job started?
Old Feb 9, 2026 | 04:46 PM
Kyle L's Avatar
No I don't remember signing any waivers
Old Feb 9, 2026 | 04:49 PM
Kyle L's Avatar
They stated that Oil was seeping from the Driver side valve cover. Proceeded to remove valve cover, then stated that "customer will need to perform cylinder head replacement due to jacket failure"
Old Feb 10, 2026 | 12:05 AM
Adam Deermann's Avatar
Looks repairable. Cylinder head off, driving the injector parts out from behind. Reaming the bore or sleeving the bore and there you go. Or a other cylinder head.
Do not go to the dealer, they will sell you a complete engine.
Old Feb 11, 2026 | 08:32 AM
JagCode3's Avatar
Can a tap be driven in and rotational force used to back it out?
https://www.jaguarforums.com/forum/f...2/#post2888393
Old Feb 11, 2026 | 10:43 AM
Kyle L's Avatar
Ok I may see if I can find a mechanic that can do that, thanks
Old Feb 11, 2026 | 10:44 AM
Kyle L's Avatar
I'm not sure because they've already pried the fuel injector out. Does this method works for removing the corrosion thats left over?
Old Feb 12, 2026 | 06:48 AM
JagCode3's Avatar
With the injector out they should be able to clean out the hole with brass brushes on a drill then vacuum out the debris from the cylinder. No need to remove or replace the head.
https://www.jaguarforums.com/forum/f...5/#post2576598
Is the head really cracked?
Old Feb 12, 2026 | 08:13 AM
wachuko's Avatar
Thumbs up
That was my first thought as well when I saw this thread. Vacuum in hand next to the hole, pick the mess, brass wire brush... borescope to see inside and make sure it is clean...
How did they reached the conclusion that the head is cracked?
What is the condition of the valves? Carbon build up could contribute to low compression results. Best to do a leakdown test as well.
I can understand an owner that is not used to working on their cars to be at the mercy of a shop... but there is a lot of things that can be done before even thinking about swapping an engine.
Obi
General Tech Help
Jan 12, 2026 03:51 PM
Olek
General Tech Help
Oct 29, 2025 08:53 AM
2011_XF_5.0
May 6, 2022 07:35 PM
lnlcons11
E type ( XK-E )
Dec 14, 2018 04:42 PM
