Dealer Charged me $30K and don't even know what the issue is!
Old Dec 22, 2022 | 08:10 PM
tolson's Avatar
Originally Posted by Life And Projects By Austin YOUTUBE
Thanks for the detailed info! I have been driving it as it trying to run some BGK( or whatever ya call it) performs well without going above 75-80% throttle. but this past weekend at about 40% throttle (first time its happened this low) i started getting the blinking light. so i went in a store and when i came back out and started it back up it was back to normal. So then i just took it home. my assumption is that the misfire is starting to happen at a lower threshold now.
exactly what I did man … I ran all sorts of cleaner through it.. then one day it went, you can’t clean it to fix it at this point it’s too late imo… so you can wait till it goes out or otherwise bite the bullet and fix it… it might take weeks for you to get into a shop , weeks for the parts, and weeks for the job to be finished so buy the stuff you need now and you will thank me later… these cars are known to have injector issues and I wish I did more research prior to buying …
cooling system goes out on these cars, injectors, and cats … literally I’m going to have to replace everything minus the cooling system which was all brand new prior to me buying the car
Old Dec 23, 2022 | 07:35 PM
Life And Projects By Austin YOUTUBE's Avatar
OK!, so i just bit the bullet and bought everything. for under $950. As soon as all this comes in i will get these injectors changed.
ALL THE PARTS WERE COURTESY OF THIS THREAD
PARTS TO ORDER:
INJECTORS $800
INJECTOR REMOVAL TOOL $32 INJECTOR REMOVAL TOOL $32
INJECTOR SEAL TOOL $70
INJECTOR SEAL/CLIP KIT $50
DOCS:
FUEL PRESSURE RELEASE
JLR MANUAL INJECTOR REMOVAL PROCEDURE
Old Dec 24, 2022 | 07:00 AM
KenFtype's Avatar
Banned
Default A Concerned Reader
I’m not a gear head so I’ve been reading these posts with some trepidation. Guys, I frankly want zero to do with paying to correct any of these issues. I already paid a steep price for a ‘21 F-Type R Coupe with 10k on the odometer. CPO warranty expires 12/30/2026 with unlimited miles. Car is garaged and only driven when roads are snowless, as I live in Western NY, currently experiencing a “bomb cyclone,” the latest weatherman jargon for a friggin blizzard. My other vehicle is a Volvo EV. So given everything that’s being said in these posts, it seems as though there’s a decent chance I might eventually encounter similar issues at some point, sooner or later. Ain’t no way I’m paying to correct any of them. So I’ll be moving on to my next ride before my coverage ends. Thanks for the heads up.
Old Dec 24, 2022 | 07:48 AM
CJSJAG's Avatar
I share the same opinion, Ken.
did originally think it might be worth paying JLR for the additonal 2 years of warranty, but from reading on this forum it seems that it not a great solution cover-wise or cost-wise.
So I may upgrade to a last production year 2024 R or just let my warranty run out and sell in 2016.
If it was not for the $200K price tag I would prefer to get a Tesla Roadster (new in 2023) - check out the specs for this baby!!
Old Dec 24, 2022 | 09:37 AM
KenFtype's Avatar
Banned
Default A concerned reader
Yes, agreed. And some coverage does fall off the CPO warranty. My factory warranty goes to 12/2025 or 60k miles, which I will be under, so by then is probably the optimal time to move on. Jaguar does have best in class warranties anyway! Don’t get me wrong. I absolutely love this vehicle. Had a ‘16 base v6 f-type conv and an ‘18 f-type r conv before this coupe, which I also loved but the coupe is my favorite by far. So I will definitely consider a later year R coupe when the time comes. Jaguar should also be into its EV line-up by 2025, to be based on an entirely new platform. Not familiar with the Tesla you mention. Have never been attracted to their looks, outside or in.
Old Dec 24, 2022 | 09:39 AM
CJSJAG's Avatar
https://www.caranddriver.com/tesla/roadster
Old Dec 24, 2022 | 09:47 AM
KenFtype's Avatar
Banned
Wow. That is something. Thanks.
Old Dec 31, 2022 | 02:17 AM
  #28
madomystrong_2's Avatar
more of a preventative cleaner than a cure. Those using it to improve gas mileage are apt to be disappointed.
Old Jan 6, 2023 | 10:40 AM
Here is a video showing some diagnostics. Hope this can pinpoint something. The fuel trims in the video were not all registering in the first few seconds of the video. please look @4:27 and see how all the fuel trims were responding.
Old Jan 6, 2023 | 11:58 AM
  #30
Tuning@VelocityAP's Avatar
https://youtu.be/sJQppFjL8IQ
If your Bank 2 catalyst is destroyed, that is most likely why you are getting the misfires. The catalyst clogs and creates too much back pressure, which affects the AFR in the combustion chamber, provoking a misfire. I diagnose this by removing upstream and downstream sensor on suspected bank, can either insert a borescope camera to view or the preferred method is attach a pressure change or oscilloscope to compare delta. If a large delta is noticed before the catalysts = blocked.
Also, if the catalyst had failed and broke off pieces, these pieces can get sucked back into the combustion chamber during the EGR camshaft phase cycle. If this has occurred and you're seeing misfire codes, the worst case could even be something like bent valves from the broken catalyst material.
Nonetheless, it's very rare only 1 catalyst goes out, usually the ECU will flag 1 bank and the other side is shortly lived, meaning both banks are needed when the brick starts to come apart (providing it's a not a code pertaining to a concern of the welds cracked)...etc.
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
Old Jan 8, 2023 | 08:04 PM
  #31
I have some good news!
I have installed all of the injectors and i drove around (40) miles and now the only code i get is the catalyst codes on bank 2. Initially I eventually got some misfires (if i drove it enough) but not this time. Car seems to idle better.
Next day, i decide install the 200 cell downpipes, after disassembly i find my bank 2 cat looking like this. (the pic is after i dumped out the big clusters.
However I figure this is the affect of my misfire, not the cause!
I couldn't finish my install with the pipes because i needed some flange bolts since i couldn't remove the ones in the discarded flange. After i ordered some bolts from ebay, i decided to look around under my car and inspect and i find a horribly collapsed motor mount and I order new mounts as well. After i order the mounts i go and look for a "how to" thread for the mounts and i find this.
https://www.jaguarforums.com/forum/f...mounts-221412/
Right on the first page i see this!
...and yes both of them are my symptoms!
Diagnosis:
There are three signs that you have a motor mount failing or failed on your jag.
1- Slight random misfire, this is one of these issues that your mechanic may chase for bit, replacing a coil, maybe a plug, tried a can of BG44K...and the misfire still persists. Many times with a bad mount the crank sensor will pick up on engine movement as a misfire and give you a code, sometimes the cyl # will change also. Other times it will have no codes and run great just have a clearly audible misfire that also shakes the car. Most of the time this a cold start misfire and goes away when warm, but not always. The mounts are hydraulic, meaning they have a hard rubber shell like most but are full of fluid and an internal valve to dampen vibrations.
2- Engine movement, you may notice your hood jumping up during hard acceleration, this is an extreme failure and will cause damage if left unaddressed for too long, usualyl this is the drivers side mount and the engine torque is causing the motor to rotate and lift enough to push the hood up. Easy to check for, pop the hood put your car in drive, apply slight brakes and some throttle will cause the motor to raise, if more then 3/4" you should move onto the next check. See below for an example of what this should look like when you have a failure."
So my assumption is that .....
1.) bank 2 fuel injector was going out first! (probably #8)
2.) cat gets blown out
3.) cat causes multiple misfires?
4.) motor mount also doing the same at times?
Hell I dont even know anymore, too much to think about but im fixing it all. will update with videos as well.
Old Jan 9, 2023 | 01:11 PM
  #32
JagRag's Avatar
Same engine..."different" mechanic! lol
Old Jan 9, 2023 | 10:36 PM
  #33
i did not like his method, i pulled at linear angles with the injectors, he pulled straight up! wait till i show you my video. it made it way safer
Old Jan 11, 2023 | 10:04 AM
  #34
Here is how i did my injectors. i didn't like the video of the guy using the engine hoist because it pulled the injector straight up from an angular socket. I decided to use a ratchet strap to give a large amount of pull assistance as i used my shoulder to control the exact angle of the strap and the slide hammer to lodge the injector loose.
hope this helps you guys.
Old Jan 15, 2023 | 09:16 AM
  #35
Old Jan 15, 2023 | 11:49 AM
  #36
these last 2 videos are the vids of the finds that i explained in post #31
apparently this is a big issue that triggers random misfire codes as well.
Old Jan 16, 2023 | 09:44 PM
  #37
Default I have some great news!
Everything is all back together . And this car sounds amazing! I should have a test run video by tomorrow.
Old Jan 17, 2023 | 08:26 AM
  #38
This has been a hell of a project, but with tediousness and patience i am finally to a resolution! I drove my car the entire weekend even after this video and this car actually feels faster, it idles better and im just so happy. It still feels unreal to go through that entire Jaguar Dealer experience but now i just cant wait to bring my car back for an oil change.
THANK ALL OF YOU GUYS FOR THE HELP!!
............"TEAR"
Please excuse the camera positioning at certain parts. i was paying more attention to the road.
Old Jan 17, 2023 | 10:37 AM
  #39
Tracy Rominger's Avatar
Glad you brought your cat back to life to enjoy the wild again
Old Jan 17, 2023 | 11:24 AM
  #40
skizot's Avatar
wait until you install upper and lower pulley and tune. Then you will really "feel" the difference. The Stage 2 (lower only) tune is pretty incredible by itself, so from no tune to Stage 3 will bring smiles for miles!
