Deplorable spoiler not available?
Old Jun 18, 2020 | 12:19 PM
dougdean's Avatar
Default Deplorable spoiler not available?
I ordered my 2020 F-Type SVR thinking I would get the deployable spoiler but it arrived with the fixed wing spoiler. I asked the dealer and they said the SVR had to have the fixed spoiler. I would have preferred the sleeker look with the spoiler retracted, but oh well, too late to change it. Still love my car though.😀
Old Jun 18, 2020 | 02:22 PM
powerhouse's Avatar
You can change the spoiler easily for the deployable one there not expensive and easy to do and you will have no problem selling the svr one if you want, the deployable one as with the svr is just a plug and play when swapped
Old Jun 18, 2020 | 03:01 PM
scm's Avatar
scm
Doesn't the SVR need the fixed spoiler to keep the back down at speed? I have to say I much prefer the fixed spoiler - the car looks a bit naff to me with the deployable one up, the fixed one looks great all the time!
Old Jun 18, 2020 | 03:12 PM
malbec's Avatar
The SVR has the wing in order to reach the 200mph barrier.
Old Jun 18, 2020 | 03:32 PM
Therock88's Avatar
I am confused. I understood all SVR's to have an Active wing? It does look fixed, but has multiple positions. I have never seen a "real" SVR without the Active rear wing. Maybe I missed something. I have seen aftermarket, and knock-offs...But OEm are supposed to be active. See below right from JLR vehicle info...
DC
Old Jun 18, 2020 | 06:44 PM
Luc Lapierre's Avatar
Good thing too.
Can't imagine why anyone would want a deplorable spoiler...
Old Jun 18, 2020 | 06:52 PM
BruceTheQuail's Avatar
Originally Posted by Luc Lapierre
Good thing too.
when mine is engaged it looks pretty deplorable
Old Jun 18, 2020 | 09:15 PM
dougdean's Avatar
Well guess I’ll just leave it as is, in case I get it up to 200mph😲
Old Jun 19, 2020 | 07:20 AM
SinF's Avatar
Does it come in a basket?
Old Jun 20, 2020 | 08:11 PM
BritCars's Avatar
My SVR is a 2017 but it has a deployable spoiler. Not that tab in the middle but a full width spoiler which raises up around 60mph. For vmax (200mph) it gets locked back down so it doesn't generate too much drag. Jag quotes the large downforce it puts on the back of the car even when down at speed
I thought that was standard on all SVRs but perhaps they changed the setup for 2020
Old Jun 20, 2020 | 11:53 PM
Nati's Avatar
You can get the standard deployable spoiler found on other models, but your SVR will come with a limiter of 186mph.
Old Jun 21, 2020 | 03:35 AM
malbec's Avatar
This from the documentary about the making of the F Type.
Talking about having to have a wing to achieve 200mph in the SVR.
File Type: mov
Old Jun 22, 2020 | 05:52 AM
F-Type-Type's Avatar
The deployable "inverted" WING was standard on the SVR, but the buyer had a no-cost no-reduction option to go for deployable SPOILER of the other F-type models.
It seems that in the discussion above the WING and the SPOILER are confused with one another.
A SPOILER is an air deflector, typically an upwardly inclined surface extending over (a portion of) the width of the car.
A WING is an airfoil that that develops downforce when an airstream passes the wing on both sides and a wing doesn't necessary deflect the airstream, although it will also deflect the airstream if it is arranged at an angle with the airstream, e.g. when the wing of the SVR Is deployed.
On the SVR the wing is locked in the un-deployed position to reach the 200 mph top speed. Otherwise, it is deployed above 60 mph for increased downforce.
Dougdean's SRV probably has a deployable inverted wing. It may look like a fixed-wing, but I guess that it isn't (unless Jaguar has changed the wing for the SVR for the 2020 model year, which seems unlikely).
Old Jun 22, 2020 | 08:18 AM
RIRR's Avatar
Yep, but the baskets are 2/3 empty.
Old Aug 7, 2020 | 01:36 PM
Ftyperegistry's Avatar
That is not true. Not common and hard to find but there are SVRs with the deployable spoiler option.
wilgur
Apr 25, 2025 08:35 PM
Mark G
Feb 10, 2020 02:22 PM
ssaeed1973
Oct 16, 2019 09:55 AM
MI-FType
Dec 16, 2018 11:42 PM
MI-FType
Dec 22, 2016 12:09 PM
