Differential alternate fluid/oil.
Old Sep 5, 2022 | 04:17 PM
BudgetBiker's Avatar
Default Differential alternate fluid/oil.
Wanted to share with anyone interested. I got my 2017 F-Type Premium V6 RWD automatic trans a week ago and found lots of videos of horrible diferential issues in shorter time than usual.
I did some research and found I can substitute the Castrol Bot 720 at $60/quart for Royal Purple 75w/90 for around $23/Quart.
There are other choices im sure but I have always had great results with RP. No they don't pay me but they should.
Anyways, i made a youtube video as detailed as I could. I will link it below.
Has anyone else used anything different and if so, good or bad results?
My result after several days of driving seems good.
https://youtu.be/RM3wrUjYTXs
Old Sep 5, 2022 | 05:20 PM
Awd's Avatar
Awd
Have heard a horror story of draining a diff….then being unable to remove the filler plug.
hmmm.
Old Sep 5, 2022 | 05:45 PM
scm's Avatar
scm
hmmm.
Sensible folk remove the fill plug before they drain it!
Old Sep 5, 2022 | 06:43 PM
mcphill's Avatar
I normally use Redline MT-90 in my differentials, but I thought I read it was not for use in LSD applications, so I bought the Castrol
Old Sep 5, 2022 | 07:26 PM
OzXFR's Avatar
I had my diff fluid replaced a few months ago with Motul Gear 300 LS and no problems since. Just make sure it's the LS (stands for limited slip, doh!) and not the plain Jane variety.
Old Sep 5, 2022 | 09:15 PM
lizzardo's Avatar
I used the Redline LSD flavor. They even has small (2 oz?) bottle of the friction modifier if the standard mix is a little too "grabby."
Old Sep 5, 2022 | 10:34 PM
Glad to have some feedback.
i located my fill plug looking at diagrams from other posts only to find mine was opposite side and actually not too hard to get to.
Once i sort of had it figured out by looking i started my video but didn't dialize it was a hex not a square till after I drained it. But i have parts store down the road and a motorcycle if i need anything.
my next venture will be the transmission fluid when the time comes.
Old Sep 6, 2022 | 06:58 AM
Therock88's Avatar
Good luck.
The transmission is much more complicated/involved than the Diffs. My DIY may help, and will at least give you a sense for what you are getting in to. Certainly doable, but not simple like the diff drain and fill.
DC
Old Sep 6, 2022 | 12:07 PM
@Therock88
Thanks, very helpful.
I figure ill give it a go at the trans when its due. I have done a lot of different cars over the years but never a Jaguar.
g7162002
Jun 7, 2021 02:53 PM
Tman003
Aug 31, 2017 08:16 PM
Uncle Fishbits
Aug 18, 2016 11:47 AM
shift
Jul 30, 2015 12:03 PM
Crovax
Nov 7, 2014 04:17 PM
