Differential Issues
Old Nov 27, 2022 | 03:55 AM
lossking_'s Avatar
Default Differential Issues
I have a 2014 v8s that has 92k miles. Every now and then, I'll hear this weird rattle or hum that sounds like it's coming from the rear after hard driving. I wondered if it's a loose bolt or something? Idk. Has anyone else had issues with differentials? I never had the fluid changed which is something I'm going to do. I'm hoping that sound that I'm hearing isn't metal shavings inside.
Old Nov 27, 2022 | 07:38 AM
Therock88's Avatar
Could be lots of things from your description - Heat shields, exhaust rattles, cross members, or differential. Only way to tell is to get down there and try to isolate the sound source. At 92K a fluid change certainly would not hurt. The diffs on these cars are not really problematic ( any more or less than other cars). Some have had issues, many others have not. Key is always good maintenance.
DC
Old Nov 27, 2022 | 01:03 PM
Carbuff2's Avatar
Need to check the vent plug on top to make sure it doesn't become plugged, and push fluid out of the driveshaft seal.
Holy F type
Jul 30, 2020 06:42 PM
David SD
66
Mar 15, 2019 01:52 PM
Ryan Hallas
Feb 10, 2018 04:05 PM
locabrew
Jul 31, 2010 11:59 PM
equicor
Jan 24, 2010 06:05 PM
