Disabling eco-start convertible 2014.
Old Jun 17, 2019 | 04:36 PM
Deemo's Avatar
Default Disabling eco-start convertible 2014.
Hi guys, I did a search and could only come up with one video that a fellow member had posted regarding disabling the ego-start however it looks like it’s for the coupe and the set up in the convertible looks to be different. Please see the photos below and let me know if anyone with a convertible has disabled the eco-start
The coupe set up screenshotted from the YouTube vid.
My convertible set up
Old Jun 17, 2019 | 06:45 PM
uncheel's Avatar
On a 2014, you have a second (small) battery next to the main one. Just disconnect it.
Old Jun 17, 2019 | 07:25 PM
Carbuff2's Avatar
After a week or two, either punching the ECO switch to turn it off, or flicking the switch to put the car in DYNAMIC mode, becomes second nature...
Old Jun 18, 2019 | 09:38 AM
Deemo's Avatar
So the purpose of that second battery is simply to run the eco-start?
Old Jun 18, 2019 | 12:17 PM
sov211's Avatar
Exactly. Just disconnect the + lead to the smaller battery; done! Now you will no longer be annoyed by the start/stop system...there are no negative effects whatever.
Old Jun 18, 2019 | 06:42 PM
OzXFR's Avatar
Much easier just to disconnect the earth lead which runs from the negative terminal from where it bolts to the floor.
Also there is a lot of misunderstanding about the stop/start two battery system and from all my research it works like this:
The secondary (smaller) battery is not used to start the car once it has been stopped, that is still done by the main battery.
All the secondary battery does is power the peripherals (lights, HVAC, sound system etc) for the second or two it takes to restart the car once it has been stopped. The reason for this is so the starter motor gets all the amps it needs from the main battery without the drag of also running the peripherals, and the secondary battery doesn't have enough amps to properly run the starter motor.
Then, once the car has been restarted, the main battery takes over powering the peripherals again and the secondary battery goes back to sleep.
The management system which controls the stop/start "dance" between the two batteries is fairly complicated and there are literally dozens of conditions under which the stop/start system is disabled, all listed in the Owner's Handbook.
And yes, disabling the system by disconnecting the secondary battery has no side effects at all, I have been running this way for 2 years and 9 months now with zero problems.
Old Jun 19, 2019 | 11:52 AM
Deemo's Avatar
Given the fact that I drive it in Dynamic 99% of the time and the fact that there's is such an orchestrated dance between all of it, I think I will just leave it be
I did however figure out how to disconnect that annoyingA$$ small horn that beeps on lock etc yesterday so I'm quite pleased with that :P
Old Jun 19, 2019 | 11:59 AM
DJS's Avatar
DJS
Or you could have gone into the menu and disabled it.
Old Jun 19, 2019 | 12:27 PM
Deemo's Avatar
Haha! Do tell!! I looked for it there but didn’t spot it
rexus31
Jun 24, 2018 07:59 AM
pab
XE ( X760 )
Apr 19, 2017 10:52 AM
pab
Jan 17, 2017 07:20 PM
domino_z
Apr 26, 2016 06:52 AM
Foosh
Aug 28, 2015 05:48 PM
