Does the '16 MY have a 2nd battery?
Old Jul 8, 2015 | 12:14 PM
DuhCar's Avatar
Originally Posted by Tel
To disable ECO interruptions, simply disconnect the control wiring plug, (That's the ones with the small AWG wires on going to the smaller black plug) and hey presto! No more annoying stop/starts!
Is it the plug with the yellow and green leads?
Old Jul 8, 2015 | 02:03 PM
Merlin's Avatar
Originally Posted by Foosh
Thanks, that's exactly what I've done as depicted in post #10 above.
Many have commented that it is totally unnecessary to use a maintainer since the car can sit for a month or more and still start without problems. While that may be true, it is also the case that lead acid batteries last a lot longer if they maintain close to a full charge all the time, and don't ever run down. With a BT wired to the battery buss, it's so simple to keep it plugged in, and I do that if my car is going to be idle for more than a few days.
Indeed.
Old Jul 8, 2015 | 03:46 PM
Tel's Avatar
Tel
Here you go...easy way to disable the Stop/Start ECO function.
Maybe Admin could be put in the 'Sticky' How to section.
Old Jul 8, 2015 | 04:51 PM
DuhCar's Avatar
Thanks Tel. Just did it. Started it up and the Eco button was lit, but then it went out. No errors seen. I didn't go for a drive but looks good.
Old Jul 9, 2015 | 03:16 AM
Tel's Avatar
Tel
Good, glad it worked well for you. You shouldn't get any errors/alarms.
You should see the ECO button light on startup as it does its self checks, then it will go out for good once you start driving.
If you do press the ECO button it will display that the ECO function is no longer available - What a result?!!!
Dagny
Jun 11, 2024 01:06 PM
JarodL
Mar 7, 2024 01:39 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
DuhCar
Sep 11, 2015 10:58 AM
DEklof
Sep 8, 2015 05:28 PM
