DRL J Blade dim on driver's side
Old Jul 26, 2021 | 09:38 PM
QuarkX's Avatar
Default DRL J Blade dim on driver's side
I bought my F-Type (2018 3.0L V6 Convertible) as a certified used from Jaguar recently and now notice that the driver's side DRL (J blade) only lights at the ends and doesn't present a consistent beam like the passenger side.
Is there a fix other than a full headlight replacement?
Old Jul 27, 2021 | 01:14 AM
sov211's Avatar
whatever the issue is, it will be fixed under the CPO warranty. I had an entire headlamp unit replaced because of a glue run under the lens, replaced with no questions asked under the CPO warranty. In your case there is a malfunction issue not a cosmetic issue, so it will definitely be covered.
Old Jul 27, 2021 | 10:26 AM
QuarkX's Avatar
Thanks. I will ask the dealership to look at it at the next service. It is a safety issue so they I expected it to be covered.
Old Jul 27, 2021 | 10:28 AM
DJS's Avatar
DJS
Isn't the factory warranty still active? I'd expect it to be covered, no problem.
Old Jul 27, 2021 | 10:31 AM
QuarkX's Avatar
Yes. It is still under factory warranty but I wasn't sure if this issue would be covered. I'll contact the dealer.
Squireg33
Aug 11, 2021 02:56 PM
MJB1221
Apr 3, 2021 10:59 AM
Beagle
Dec 4, 2015 02:27 PM
Broken_Spanners
Nov 12, 2014 04:53 AM
Blue XK8
Oct 27, 2013 06:25 PM
