DRS not working
Old Dec 6, 2016 | 01:10 PM
drewguy's Avatar
Default DRS not working
the spoiler button doesn't seem to be working for the past few days I have tried it in many different situations (park, drive, different speeds , etc) I remember it working when I got the car about 2 weeks ago. It does pop up when reaching the right speed just not with the button, what am I missing ?
Old Dec 6, 2016 | 01:20 PM
Tommy Ferrugia's Avatar
Have you tried holding down the button, rather than quickly pressing it? I noticed that the spoiler's actuation on my car isn't intuitive either. I have to try it a few times in order to get it to work properly (though in 3 months I may have manually deployed it a total of 4 times).
Old Dec 6, 2016 | 01:31 PM
drewguy's Avatar
yes sir, tried holding it down for a while , pressing for different lengths of time. Yeah I suppose it's not a serious issue I'm debating if I should even bother bringing it in to get it looked at. Just wanted to see if I was missing something obvious
Old Dec 6, 2016 | 01:43 PM
Unhingd's Avatar
What model year, coupe or vert?
Old Dec 6, 2016 | 01:44 PM
drewguy's Avatar
2017 f-type coupe, the button is right there! I remember it did work once
Old Dec 6, 2016 | 01:49 PM
If it still deploys automatically once the car exceeds 60 MPH, then it sounds like a faulty switch. If the car is still under warranty (which it should be), then you should absolutely bring it in. I'd suggest making a punch list of EVERY issue the car may be having and getting them fixed for free; I mean, why not?
My car is a 2014 V8 S and I bring it in for EVERY SINGLE niggle and inconvenience. I want the car to be in the best condition possible before the warranty expires. You paid a lot for your car and everything should work as expected.
Old Dec 6, 2016 | 01:50 PM
drewguy's Avatar
If it still deploys automatically once the car exceeds 60 MPH, then it sounds like a faulty switch. If the car is still under warranty, then I'd bring it in and get it fixed for free; I mean, why not?
yeah it does pop up after 60mph, I suppose you're right I just made an appointment. Will update with result on friday.
Old Dec 6, 2016 | 04:44 PM
Holy F type's Avatar
For my car, a 2016 coupe S, it has to be with the ignition on, you can't manually raise it while you are driving or the engine is idling, it is called "cleaning mode" and it is there to lift up the spoiler with the ignition on to wash right under.
Old Dec 6, 2016 | 05:31 PM
Unhingd's Avatar
Per the owner's manual (and my experience) the button on the Coupe is only functional with the ignition on and the car at a standstill. Otherwise it automatically goes up at 70mph and back down at 50. The sole purpose of the button is to raise the spoiler to clean underneath. (or to stencil "Bye, Bye!" on the underside).
Old Dec 6, 2016 | 07:18 PM
IRRBrogue's Avatar
If I remember correctly, the US coupe can only deploy at speed, since the spoiler sticks out a fraction of an inch beyond the rear bumper, and can thus be a danger when backing into a pedestrian. Thank you Federal Government.
Old Dec 6, 2016 | 07:51 PM
lizzardo's Avatar
If you really enjoy backing into pedestrians, you've got to get something classic, with lethal tail fins. This new stuff just doesn't cut it (pun intended).
Old Dec 6, 2016 | 08:40 PM
IRRBrogue's Avatar
Well, I did briefly own a Daimler SP 250 (Dart). Check out the fins on that baby.
Old Dec 6, 2016 | 08:46 PM
lizzardo's Avatar
Anything called "Dart" gets the Pedestrian Safety Seal of (Dis)Approval.
Old Dec 9, 2016 | 02:11 PM
drewguy's Avatar
yeah honestly this issue for me isn't a big deal I actually didn't end up going to my appointment anyway lol
Old Dec 9, 2016 | 03:21 PM
amr42's Avatar
and FWIW, the vert's goes up at 60mph and down at 40mph...
Old Dec 9, 2016 | 03:32 PM
DJS's Avatar
DJS
And, if you want to properly ****, on the vert you can raise/lower the spoiler manually below 40MPH. At least, on the 2014 you can.
Old Dec 11, 2016 | 07:52 AM
CW3SF's Avatar
On mine, I can raise or lower it moving or parked using the button as long as the ignition is on. 2014 V6S vert.
Old Dec 11, 2016 | 08:26 AM
Unhingd's Avatar
The owner's manual specifies that can be done on the vert...not on the coupe. But not why?!?
Old Dec 15, 2016 | 03:23 AM
fstopst's Avatar
you can only deploy the spoiler on a coupe when standing still. i was stuck at this conundrum a few days as well. I think the reason behind it is rear visibility on the coupe. Non-moving deployment allow you to clean or service around the area.
Old Dec 15, 2016 | 08:28 AM
Unhingd's Avatar
You make an excellent point. The vert spoiler is much shorter (but wider), allowing better visibility than the coupe spoiler when deployed.
