Eco mode set at 30 sec approx
Old Sep 1, 2017 | 12:23 PM
aden25jones's Avatar
Default Eco mode set at 30 sec approx
Loving my F type S, 2014 model.
With eco mode enabled, how do I change the timer on this from say default 30s when foot on brake to 1m or 2m.
Any help would be much appreciated.
AJ
Old Sep 1, 2017 | 01:23 PM
Unhingd's Avatar
AJ
Don't quite understand the question. Are you asking about the time until it shuts the engine down or the time until it turns back on again. Depending on battery condition and load, mine will immediately shut off at a stop. Has nothing to do with a timer. Engine won't restart until battery charge is down, Climate control calls for it, clutch is depressed, or steering input calls for it.
Old Sep 1, 2017 | 03:48 PM
bigdaddy's Avatar
You're probably running the AC OP ?
I tried turning the AC off and it seems like the car stays off until you're ready to go.
Old Sep 1, 2017 | 04:51 PM
Thanks. will try with a/c off. Defo a timer. Perhaps a software issue and an upgrade is needed
Old Sep 1, 2017 | 04:56 PM
Chawumba's Avatar
Disable that steaming pile of an option....
I removed the second battery to kill mine off and saved 10 lbs.
Old Sep 1, 2017 | 05:19 PM
DPelletier's Avatar
agreed; no timer on mine
Dave
Old Sep 1, 2017 | 06:01 PM
IronMike's Avatar
This!!!
Old Sep 1, 2017 | 07:18 PM
Unhingd's Avatar
Originally Posted by IronMike
This!!!
That only works on the Classic F-Types (MY '14-15).
Old Sep 1, 2017 | 07:33 PM
Dogbreath!'s Avatar
Since I commute in mine, I've gotten used to ECO. Flipped me out the first few days that i owned the car. My only gripe is that it is a bit ragged sometimes starting when I let off the brake. But in the 1.5 years that I've had the car, I bet that ECO has save a whole gallon of gas.
Old Sep 1, 2017 | 08:28 PM
DirtyAir's Avatar
I vote for the VAP mod to turn eco off. As a bonus, you also get extra horsepower!
Old Sep 2, 2017 | 07:15 AM
No wonder they call you the Big Daddy!
Big Daddy you were correct. Did a time check with air con off and could not get the engine to start again. Thank you. This has resolved the issue. With winter coming in UK this is all good.
