Eco Switch and Whistling
Old Sep 6, 2021 | 12:19 PM
Tom61's Avatar
Default Eco Switch and Whistling
Hi All, I've appreciated reading all the questions and responses. Here are mine for you all. I am new to Jaguar (very excited) and just purchased a 2015 F-Type V8 S and have 2 immediate questions. 1) The engine shut off/start does not activate even with the "Eco" switch on and engaged. Hints on what may be going wrong? and 2) With the top down, there's a bit of an annoying whistling noise coming from the space between the driver's side mirror and the A pillar. If I put a finger or 2 in that space the whistling stops. Suggestions for a fix? It seems to whistle at 45 mph and up. Thank you in advance for all your expertise and any suggestions. Tom
Old Sep 6, 2021 | 12:30 PM
eeeeek's Avatar
I didn't know they made a V8 S in 2015. It might be a country thing.
I'm not sure why you would want the Eco switch to work; however, the secondary battery is probably dead. The first few years used a second battery just for the eco function. Me, personally, the first thing I did on my F-Type was to disable the eco button.
Old Sep 6, 2021 | 12:47 PM
scm's Avatar
scm
What's an eco button? I've got a button to enable/disable stop/start but there's nothing about the F-Type that's eco.
Old Sep 6, 2021 | 06:34 PM
Borbor's Avatar
The original owner has disconnected to stop start already. Search the threads for how to disconnect if you want to undo it.
Old Sep 7, 2021 | 10:13 AM
RGPV6S's Avatar
In my 2014 the second battery died and the stop /start function stopped working. I never replaced the second battery because the start/stop function had an unacceptable restart delay and was generally annoying.
Old Sep 7, 2021 | 10:26 AM
clubairth1's Avatar
Community Influencer
The start stop system is somewhat failure prone. It most likely is the battery as posted above but on my 2014 XJR I replaced the small AUX battery and it worked for a short time. Them it stopped altogether which was fine by me! Recently I hooked up my SDD and found a Start/stop error code which points to an electrical problem that I will NOT be fixing!
Brutal one of our factory tech's has posted that there was a lot of electrical failures with that system.
scottjagf
Mar 2, 2021 05:18 PM
MisplacedPriorities
Sep 5, 2019 09:17 PM
aquifer
Jun 11, 2019 10:36 PM
byrnew
May 18, 2018 07:16 PM
concertoed
Jan 18, 2016 01:06 PM
