Electrical gremlins!
Old Dec 22, 2023 | 06:59 PM
Thunder Dump's Avatar
This sounds like a loose common ground somewhere. There are multiple grounding points on the car (not just the battery) and I've seen people who have found ground leads that have either corroded through (most common--especially for those in/under the engine bay) or loosened to where they are not reliable any more.
Old Dec 22, 2023 | 07:00 PM
Originally Posted by bfrank1972
Next I'd confirm those grounds. Especially the one connected to the transmission middle of the car, get underneath and see if it's corroded.
This. A very common one.
Old Dec 22, 2023 | 07:22 PM
Roost5o's Avatar
gonna have to have a look I reckon
Old Dec 22, 2023 | 08:42 PM
bfrank1972's Avatar
think of it as an opportunity to bond with your car
Old Dec 22, 2023 | 09:32 PM
Roost5o's Avatar
Indeed sir!
Old Dec 23, 2023 | 04:53 AM
scm's Avatar
scm
There's a ground point in the front right wheel well where folk on the UK forum have found corrosion issues.
Old Dec 23, 2023 | 07:46 PM
lizzardo's Avatar
I've only had two electrical issues. The first was a loose battery terminal. The pinch bolt was tight but it wasn't clamping to the post. I needed to expand the terminal a bit so it would tighten properly. The second problem I had was from rodents chewing on the wiring going to the antenna for the passenger side keyless entry antenna. I hope you don't have that problem (rodents, that is).
JeremiahLovesJags
Dec 26, 2022 06:29 PM
Vision
Aug 19, 2021 10:39 AM
khsjsilver
Jul 27, 2021 09:02 AM
AttyDallas
May 28, 2020 12:51 AM
agentorange
Feb 11, 2017 11:13 AM
