emergency Brake sticking
Old Jun 28, 2020 | 09:49 PM
Bruce Weller's Avatar
Default emergency Brake sticking
Hi have a 2016 Jag F Type manual. 6 cyl.. I notice too many times if its sits in the garage for over 2 weeks I can barely get it to engage as the emergency brake sticks.. its really hard to move it to dissenge it .. Under 2 weeks its no problem but getting very annoying I fear that one day I wont be able to move it. Is there a way to disengage the automatic parking brake and only have it engage when I want to engage it.. Is there something I can unplug to do that.. or is there something I can pull the rear wheels of and lubricate.. Thanks Bruce
Old Jun 29, 2020 | 10:40 AM
Carbuff2's Avatar
Ever had the rear brake pads replaced?
If so, were the motorized parking brake actuators properly placed into the MAINTENANCE mode? Or were they man-handled to make the caliper pistons retract?
Perhaps just cycling the Maintenance Mode will help, it certainly couldn't hurt.
To Put the car in brake maintenance mode. Ignition on, push the hand brake button down and hold for 2 secs, press accelerator to the floor and hold 2 secs turn ignition off/on and release accelerator and hand brake button. Dash should now read Brake Maintenance Mode. This retracts the EPS motors to allow you to push the piston back in. No tools needed.
To take the car out of brake maintenance mode. Ignition on, pull the hand brake button up and hold for 2 secs, press accelerator to the floor and hold 2 secs turn ignition off/on and release accelerator and hand brake button. Dash should now clear Brake Maintenance Mode
Lots of Topics by searching parking brake maintenance mode on the Forum.
Old Jun 29, 2020 | 02:18 PM
I will try the cycling the maintenance mode ..thanks for how to do it...no I never messed changing brakes but previous owner might of...ive had the car for 1 year...and I'll report back if works....other than that...there is no way to disconnect the auto parking brake..not like I really need it curious do the automatics also have this feature
Old Jun 29, 2020 | 02:39 PM
scm's Avatar
scm
My manual says to disable the feature on switch-off, when the vehicle is stationary press and hold the EPB switch in the release position (down), switch off the ignition within 5 seconds and continue holding the EPB switch for a further 2 seconds.
Old Jun 29, 2020 | 03:41 PM
AWESOME! Im going to try that today , if that works that would be great then I can dissable it when I am parking for longer than weeks.. adn I assume it just re-enables next time you start it.. cool thank you.. no more sticky brakes.. the last time I tried to take it out of the garage after being parked for 3 months i had to keep slipping the clutch and reving it to get it to POP not good..
Old Jun 30, 2020 | 12:12 AM
Thank you so much works great to turn off whenever you want to and resets back on next time car is started.. what I was looking for awesome Thanks
Old Jun 30, 2020 | 04:21 AM
scm's Avatar
scm
A win for RTFM!
CarsonCitySmith
XF (X260)
Apr 20, 2020 03:45 PM
David Meier
Oct 3, 2019 08:37 PM
LedZepplin
Aug 14, 2017 10:30 AM
Emkay
Jun 23, 2015 12:51 PM
Muti007
Feb 22, 2015 12:14 PM
