Engine oil Leak, Need new front brakes.
Old Aug 15, 2025 | 06:55 PM
Lavitz's Avatar
Default Engine oil Leak, Need new front brakes.
About 3 weeks ago, I noticed two spots of engine oil on the garage floor. I’m not exactly sure where it’s coming from, but it appears to be toward the back of the engine. I’ve attached a screenshot. Since then, there haven’t been any more oil spots, and I’ve driven the car 3–4 times.
My questions are:
  1. What could be causing this?
  2. What should my next steps be to diagnose or fix it?
Also, I need to replace my front brakes. Can anyone recommend pads and rotors that would work well for my 2015 Jaguar F-Type V6 Coupe?
Edit: been quoted $1600 CDN for front brakes, rotors and sensor : is this reasonable. Jaguar quoted me 2800.
I am planning on going with it and having them diagnose the engine oil leak.
Old Aug 15, 2025 | 07:49 PM
Carbuff2's Avatar
The car needs to be put on a lift, undertray removed, then investigate the leak's source. If the oil stains are difficult to pinpoint, then everything needs to be cleaned up, driven for a period of time, then re-evaluated. Would help to see where (in relation to the car) the drips are positioned.
If the Jag dealer wants to use original dusty, grabby pads, buy Porterfield R4-S and have an indie shop install them. Rotors don't need to be replaced each brake job (experience here is that they will last two sets of pads), but most shops like to do it all....
OzXFR's Avatar
As I said before in the XK thread you can get R1 Concepts rotors and Porterfield R4-S pads which are better than the OEM ones and a lot cheaper, around $500 CDN for the lot.
You can also fit them yourself and save a packet, it's a relatively straightforward job if you are even mildly handy with the spanners.
The only "special" tool you will need is a 9 mm hex driver for the front caliper slide pins, plenty on Fleabay.
Old Aug 15, 2025 | 07:50 PM
SS4PK's Avatar
I replaced all 4 rotors and all pads with Porterfields for $800. I did the work. Do not buy Jaguar rotors they are way too costly.
Old Aug 18, 2025 | 01:55 AM
Lavitz's Avatar
Could I get a link to the rotors and pads. Ill order them. No point in spending $1600 just for fronts. I found a indie shop that can do them relatively cheap.
Im going to take car into jag for oil issue i dont want that lead to a big problem. Ill take premium price hit on that.
Old Aug 18, 2025 | 07:29 AM
Robtrt8's Avatar
Several sources for oil leaks.
#1 is the brake boost vacuum pump. Dealer will want a grand to drop all the oil, clean the effect area, replace the pump, change filter and add oil.
All you need is a new pump from FCP and a Husky very low torque wrench from Depot. Put the front of the car up on stands so the oil won’t drip out too much. Clean effect area and swap out pump. Watch torque specs on the two bolts.
#2 is the oil filter housing. If you’re using aftermarket oil filter kits you should look at the housing where the black cap screws down. Aftermarket gaskets don’t seal as well as legit JLR seals. Oil drips out all over the passenger side front of motor coating the alternator which can lead to early failure.
#3 is valve cover gaskets. I’m willing to accept a little seepage here because changing them out is not cheap.
Old Aug 18, 2025 | 10:24 AM
eeeeek's Avatar
With the undertray, I don't think you can tell if a leak is in the back or the front of the engine. It's going to just come out where the undertray lets it.
Old Aug 18, 2025 | 05:49 PM
Lavitz's Avatar
https://frsport.com/products/porterf...MaAtp0EALw_wcB should I order these ?
Okay so...
The bottom of my car did hit a speed bump. I think that cause leak.. what could this be ? No im freaking out.
Old Aug 18, 2025 | 08:04 PM
OzXFR's Avatar
Okay so...
Those are "base" model 355 mm front brake pads, no good at all if you have an R or V6S etc with the 380 mm front brakes.
But on the same web page if you scroll down a ways you will see the correct pads for the 380 mm brakes, AP1750.
Old Aug 19, 2025 | 11:15 AM
Lavitz's Avatar
Oil level sensor is where the oil leak and one other spot. Ive attached the video. Thoughts.
https://rotracker.goauto.ca/?share_key=fr9YF-XuGkvsgetW8aWgf3CmVtA=
jaguar response
Recommend to replace oil level sensor along with an oil change $1209.89+tax. and monitor the sipping from the rear main area. And recommend to replace front brake pads and rotors $2427.51+Tax. Please let me know how you would like to complete the repair. Thanks.
Old Aug 19, 2025 | 12:06 PM
zach05855's Avatar
Deleted
Old Aug 19, 2025 | 12:17 PM
Robtrt8's Avatar
Have your independent do the oil sensor, have him check the brake boost vacuum pump and the oil change. I wouldn’t worry about a rear main seal yet. Oil sensor costs $100 from Harper Jaguar Parts.
Those front brake rotors look perfect. No reason to change them. Just pad slap them with Porterfield R4S pads.
Old Aug 19, 2025 | 01:04 PM
Lavitz's Avatar
okay, ill look for a local mechanic.
https://www.velocityap.com/product/j...front-ap-1750/ should I order these ?
Old Aug 19, 2025 | 01:09 PM
Robtrt8's Avatar
Check fitment.
https://porterfield-brakes.com
Old Aug 19, 2025 | 04:13 PM
Lavitz's Avatar
https://parts.harperjaguar.com/oem-p...Y2LWdhcw%3D%3D Is this the correct part for the oil sensor ?
Old Aug 19, 2025 | 10:49 PM
WhiteTardis's Avatar
That doesn't look like oil; it looks like water mixed with soot. At any point did you have your car parked backed in? F-TYPEs will drip condensation from the exhaust; mixed with the soot and it looks exactly like that.
https://www.jaguarforums.com/forum/f...t-what-125605/
Old Aug 20, 2025 | 12:15 AM
OzXFR's Avatar
Agreed, looks like the classic sooty water drip to me, how did we all miss that?
If so nothing to worry about.
Old Aug 20, 2025 | 02:28 PM
Lavitz's Avatar
Its def oil, the jaguar guys charged me $600 for diagnostic. Kinda crazy but sensor i linked the correct one ? Also I posted their video with their analysis.
Nvm after speaking to the rep he said its not an oil leak. Dang i wish i saved the $600, rip. Alright just replacing brakes.
JagWRLD
Sep 8, 2024 07:46 PM
Freddy J
Sep 7, 2021 11:31 AM
Geoff_C
Oct 5, 2020 02:21 AM
F1Virginia
XE ( X760 )
Sep 29, 2020 08:49 PM
watson6505
Nov 28, 2019 12:03 PM
