This is exactly how much window washer fluid are reservoir can handle.
Old Jan 31, 2021 | 07:51 PM
Uncle Fishbits's Avatar
Default This is exactly how much window washer fluid are reservoir can handle.
*our (voice-to-text error pardon)
I don't know if it's because it's in the rear, but I'm pretty shocked how big a reservoir that is. This is what is left over from filling it up from a 1 gal, or 3.78 l bottle.
Old Jan 31, 2021 | 08:06 PM
garethashenden's Avatar
My XJR is similar. Always an annoying small amount left over. Too much to throw away, but not enough to be useful later.
Old Jan 31, 2021 | 09:24 PM
Therock88's Avatar
It actually has 2 reservoirs...1 behind the right wheel apron, and the other inside the rear bumper. When the front one gets low, a pump kicks on and refills it from the rear one. Total is 5.8 Qts! I use it for Water/ Methanol Injection(shared) too, and it lasts quite a while thankfully..
DC
Old Jan 31, 2021 | 10:37 PM
davidlg16's Avatar
any window washer fluid is fine? not some specific ones like the engine oil?
Old Feb 1, 2021 | 08:09 AM
Carbuff2's Avatar
I hope not, I've refilled with the same blue -25F. stuff I use in all my cars. (Hey, the cap is BLUE so it MUST be OK. )
Old Feb 1, 2021 | 01:32 PM
Therock88's Avatar
Not really an issue with WS solution, unlike many other fluids! Since I am "sharing" the reservoirs for my Water/Methanol injection, I only use the -20 degree WS Solution, that is about 30-40% Methanol, and the rest Water (and a drop of blue coloring).
The Jaguar spec indicates - Screen wash with frost protection, diluted with clean water to the ratio specified on the screen wash bottle - But again, any normal solution should be fine. You DO want to only use the low temp types if you live in colder climates, or it will blow off your headlight washer covers and/or could crack your nozzles when it freezes!
DC
Old Feb 1, 2021 | 02:01 PM
cpq100's Avatar
I think the reservoir is that large due to the headlight washers. I have a Volvo with headlight washers. The reservoir on that car is 5.8 quarts. The first time I filled it I was looking for fluid on the ground after adding a gallon and still not filling it.
Old Feb 3, 2021 | 04:01 AM
takeapieandrun's Avatar
So a dry windshield washer reservoir will save you 11.6lbs @ 5.7qts. Seems like quite a bit for free weight reduction. Personally, I never use it as I my car is garaged and i wash my car often enough that the windshield is always clear.
ATFS13XFR
Oct 15, 2017 02:14 PM
King Charles
Jul 18, 2014 02:51 AM
intdiamond
Jul 13, 2014 07:57 PM
Jon89
Oct 3, 2012 10:46 PM
JessN16
Aug 9, 2010 01:23 AM
