Exhaust pop for new 2 litre f type?
Old Mar 8, 2020 | 01:46 AM
Creweton's Avatar
Default Exhaust pop for new 2 litre f type?
I have just bought a new 2 litre F Type and watched virtually every video review. I seem to be lacking any exhaust crackle/pop heard on those videos. I appreciate it's only the 4 cylinder. Any ideas hints or tips?
Old Mar 8, 2020 | 05:11 AM
BruceTheQuail's Avatar
Driving it dynamic might help, if you arent already. But I have noticed that our XE with that engine (different exhaust) has quite a lot of grumbling on the overrun and when gears are changing, but you hear it from outside more than inside. Try driving in in manual mode and see if you get the crackle when you take your foot off the accelerator.
Lovely engine, by the way - hugely impressive.
Old Mar 8, 2020 | 05:14 AM
scm's Avatar
scm
I've heard that the sounds improve as you drive the car, so may also be a "running in" thing ....
Old Mar 8, 2020 | 03:27 PM
Tomkatb's Avatar
I own one! Just got in from a 30 minute trip around the block. The DW refers to it as the long block.
It will get a little louder as you own it. Some break in.
Acceleration times 0-60 require the use of the launch control. Subtracts about a second.
If you want the most noise drive in Dynamic with the transmission in s. Takes a little practice. Throttle control.
Plenty of pops for an adult.
Old Mar 8, 2020 | 05:21 PM
Dan_NL's Avatar
If you want to keep grinning on the long run, better is to run it in first before starting with launch control...
https://www.ownerinfo.jaguar.com/doc.../proc/G1898192
Old Mar 9, 2020 | 08:36 PM
tgx.trf's Avatar
2019 P300 owner here and I can confirm the following
1. Follow the proper engine break in from user manual, I didn't switch to dynamic mode for the first 5000KM
2. Confirmed it gets louder after break in
3. Yes, P300 2L does pop, especially when you let go of gas
4. No you cant compare against the loudness of a V8, its a little Jar after all.
Cheers, TGX
Old Mar 10, 2020 | 02:15 PM
Parfect's Avatar
Does the P300 have dynamic launch?
Very easy to get the pops on over run once broken in. I’ve had issues with the valves sticking closed on my MY19. Dealer is going to look at it next week when it’s in for it’s service.
Old Mar 10, 2020 | 03:38 PM
scm's Avatar
scm
Yes.
X-Type Owner
Sep 11, 2019 08:35 AM
strippersteel
Aug 18, 2016 07:57 AM
leedanielwells
Apr 12, 2014 06:25 AM
