EZ PASS toll problem ...
Old Sep 18, 2016 | 08:45 AM
Ubad2's Avatar
Banned
Default EZ PASS toll problem ...
Hi guys,
I tried using my valid EZ PASS transponder while driving through a highway toll and for some unknown reason, my EZ PASS box doesn't work. I keep it inside the car and place it onto the inner windshield as I approach the toll but the EZ PASS system keeps telling me, EZ PASS not read. Unpaid toll. I keep going through tolls without paying. Then several days later I receive a letter asking for payment plus a fine amount for this infraction. My car is a 2017 car. Can anyone shed some light on the problem. I call EZ PASS customer service to complain but they keep telling me that my account is in good standing and there is no problem from their end. What's going on ???
Thanks.
Old Sep 18, 2016 | 09:30 AM
lsbrodsky's Avatar
The 2017's have that heat reflecting windshield that has your problem well documented. It won't pass the reader waves either. Jaguar says try the upper windshield next to the mirror. If that does not work you are SOL. One of the reasons I am glad I have a 2016.
Larry
Old Sep 18, 2016 | 09:42 AM
BritCars's Avatar
Originally Posted by Ubad2
Hi guys,
Thanks.
Yes - the windscreen can attenuate the EZPass signal. They make an alternative transponder that attaches to the front license plate so that it's already outside the car. Lots of the Germans (BMW / Mercs) have it. I hadn't seen it as an issue on the Jags before but should be solvable with the front plate transponder
Old Sep 18, 2016 | 09:49 AM
amr42's Avatar
And if your state doesn't require a front plate, then use one of these:
https://www.jaguarforums.com/forum/f...racket-144955/
But with further thinking, the transponder will NOT be secure - since you can release this device with the simple pull of a pin... Check with the vendor - they are VERY helpful!
Dogbreath!'s Avatar
My boss had the same problem on his Land Rover. The license plate xponder fixed it.
Old Sep 18, 2016 | 09:59 AM
ek993's Avatar
Try positioning it to the right of the rear view mirror, - not sure if anything changed for the 17 model year but there should be a small area there that allows the signals to pass through the glass
Old Sep 18, 2016 | 11:08 AM
Unhingd's Avatar
+1. Try that first. Otherwise the plate transponder can be mounted to that bolt that the StoNSho uses (if you don't use a front plate).
Old Sep 18, 2016 | 02:56 PM
Ubad2's Avatar
Banned
Default Thank you guys ....
Okay, well now all of this makes sense. It was driving me crazy every time I went through a toll. The issue is the front windshield, got it.
Thank you
Old Sep 18, 2016 | 06:06 PM
Nati's Avatar
Yep. Same technology has rendered my $500 radar detector useless. If it was optional I would've picked a different windshield.
Old Sep 18, 2016 | 07:07 PM
carzaddict's Avatar
im having the same issue with my windsheild. the ezpass transponder works 95% of the time, but the radar is giving me fears because it didnt pick up on 2 cops that i passed that had their radar guns out
Old Sep 19, 2016 | 12:37 PM
Kitesurfer's Avatar
If you have zero deductible glass you may want to consider the sledge hammer option and ask for a 2016 windshield. Just sayin'
Old Sep 19, 2016 | 04:29 PM
Ubad2's Avatar
Banned
Default Funny guy ...
Lol... : )
Old Sep 19, 2016 | 07:58 PM
mrveda's Avatar
I just purchased a 16 R F Type in Florida. Are you saying an Escort Passport radar Will work or intermittently only?
Old Sep 19, 2016 | 11:45 PM
Nati's Avatar
You should be fine. I think the infrared reflective windshield is only standard as of 2017.
Old Sep 20, 2016 | 01:16 AM
IronMike's Avatar
I hate the appearance of toll transponders stuck to the windshield. The F-Type is the third car I have attached my transponder to the moon roof glass instead. Works fine. 100% of the time.
In fact, on two cars, the transponder is mounted to the top side of the sliding sun screen, between it and the moonroof glass, so you can't see it from inside the car, and almost impossible to spot from outside. There is less clearance here on the F-Type, but I improvised and still got it done.
Old Sep 20, 2016 | 06:42 AM
Unhingd's Avatar
I painted the transponder black. Absolutely cannot see it.
Old Sep 20, 2016 | 06:47 AM
Arne's Avatar
So did I. Here is what mine look like:
Old Sep 21, 2016 | 07:40 AM
gverntz3's Avatar
Default Which Side is EZ-Pass Mounted
Is it left or right of the rear view mirror?
Old Sep 21, 2016 | 08:12 AM
Arne's Avatar
Mine is not the EZ Pass, but a similar Norwegian toll road system, and it is mounted to the left of the rear view mirror.
It looks like an oem part of the car, but it was originally white before it was painted matte black.
Old Sep 21, 2016 | 02:06 PM
carzaddict's Avatar
slightly off topic: i noticed you're in NJ, a bunch of us are getting together at "the fireplace" in paramus on sunday 9/25 at 9am if you're interested in joining
