F-Type Clutch Replacement Options
Old Jul 4, 2024 | 03:30 PM
  #61
lizzardo's Avatar
Originally Posted by HermanWiegman
Steve, did you have an NVH issues that is annoying you?
The only time I had NVH issues was when my dual-mass flywheel was failing. I asked because it seemed a reasonable question in the context of light flywheels and the vibrations you've noted in the various combinations tested. I try to keep my eyes open for possible improvements.
Old Jul 4, 2024 | 07:58 PM
  #62
HermanWiegman's Avatar
Steve,
Fair enough. Thanks for your concern.
When we drove VW bugs in the 1970’s and 80’s, no one complained about driveline vibrations when lugging the car up a hill.
Well, OK, the back seat passengers would yell at the driver to downshift.
So I downshift to address the NVH at low RPM in my lightweight flywheel equipped F-Type.
BMW (and many other makes) use rubber isolators in the driveshaft to provide some torsional dampening.
This should help, but I like the more solid feel of the F-Type’s mechanically tight driveshaft.
The XK8 came with driveshaft isolators…. Hmm… that could be an option to reduce NVH in my F-Type Manual.
But I would have to change over the output flange of the Tranny and Rear Diff…. Or splice in the XK style driveshaft to the 6bolt flanges.
It could be done…
Old Jul 7, 2024 | 07:45 AM
  #63
Update:
I finally found the appropriate friction disc for the "Sport Touring" application.
The below friction disc has the correct specification:
  • 8 mm thick, correct hub and splines
  • transmittable torque up to 530 Nm
  • organic material with copper flake,
  • Marcel springs pointed in the correct orientation
  • sprung center (spring pack to flywheel side)
This friction disc comes from a Porsche 996 non-turbo application which uses the same pressure plate as the Onca Engineering solution, and also interfaces with a deep dish flywheel.
I purchased the disc from a Porsche/Audi/VW upgrade shop in California and it appears to be a commissioned design from ACT.
I will be fitting it to my V6 MT F-Type in the coming month to test it out, and I will then report back the results..
Porsche 996 non-turbo friction disc
Old Nov 12, 2024 | 09:32 PM
  #64
CiscoKidInSF's Avatar
Where/How couid I order the very same kit for my 2016 Manual F-Type? Please let me know, if I have to assembly myself, could I please have the part numbers?
B) A second conversion kit has been assembled and delivered to @Blue-F A picture of the parts is shown below.
  • Lightweight Flywheel from Aasco Motorsports
  • Pressure plate from ACT
  • Friction disc from ACT
  • Clutch alignment tool from ACT
  • Throw Out Bearing from FTE
  • Flywheel bolts from Jaguar
  • Clutch bolts from Jaguar
Old Nov 13, 2024 | 06:48 PM
  #65
Onca Engineering's Avatar
@CiscoKidInSF
Great to see your interest in the light weight flywheel kit which gives 25% faster engine RPM response and quick shifting at high RPM.
I have the significant portion of the kit in stock and available. We can talk about the smaller bits.
Note: Onca Engineering has taking the time to develop and document the many refinements to the upgrade kit so that other Jaguar enthusiasts can enjoy the results upon conversion. Please work with me to achieve your goals for your Jaguar experience.
Check e-mail from OncaEngineering@gmail.com
Best, Herman
Manual-S
May 11, 2021 05:15 PM
mwigent
Jul 14, 2019 09:28 AM
Mr_metro
Oct 27, 2018 02:26 PM
Unhingd
Sep 18, 2015 07:00 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
